> ecord(stringout, "$(P):$(R):startdaqfile")
> field(DESC, "start DAQ into FILE")
> field(OMSL, "CLOSED_LOOP")
> field(DOL, "filename.VAL")
Should it be:
field(DOL, "$(P):$(R):filename.VAL") ?
Cheers,
Matt
> field(DTYP, "stream")
> field(OUT, "@callbash.proto callbash(STARTDAQFILE) dummy $(A)")
> My .prot protocolfile looks like this:
> callbash {
> exec 'system "./daqcontrol.sh \$1 %s"';
> And the shellscript daqcontorl.sh like this:
> #!/bin/bash
> echo DAQ control
> echo called with command: $1
> echo filename: $2
> The first record should hold a filename of the datafile to be written,
> the second record launches the shell script which starts the DAQ with
> certain command and filename.
> command "STARTDAQFILE" specifies the DAQ mode.
> the second parameter is the filename to be used when starting the DAQ.
> My idea was, that this filename is taken from the first db-record.
> My understanding from the manual is, that if i specify "OMSL
> CLOSED_LOOP", then the output value is read from the given link, and not
> from the actual value written to the record.
> But if i now do a "caput XYTABLE:startdaqfile 1" (or alternatively
> "caput XYTABLE:startdaqfile.PROC 1") then my shell script is called with
> two parameters:
> "STARTDAQFILE" and the number i use in the caput command.
> The filename from the first record is ignored.
> Any idea what i am doing wrong ?
> This is the last piece i am missing to get it running...
- Re: how to issue a shell command from EPICS record ? Konrad, Martin
- Re: how to issue a shell command from EPICS record ? Pavel Maslov
- Re: how to issue a shell command from EPICS record ? Christian Pauly
PTP/MTP/libgphoto2 camera triggering + EPICS? Gomella, Andrew (NIH/NHLBI) [F]
Re: EPICS Training Vikas Kumthekar
<2013>
Re: how to issue a shell command from EPICS record ? Dirk Zimoch
<2013>
