1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: how to issue a shell command from EPICS record ?
To: "Konrad, Martin" <[email protected]>
Date: Thu, 03 Oct 2013 11:53:21 +0200
On 02.10.2013 17:08, Konrad, Martin wrote:
Hi Dirk,
StreamDevice. It has an exec command.
Doesn't the exec command only pass commands to the IOC shell? Christian
was asking about running a bash script. Is it possible to run that as well?
Martin
3.14.12 implements the "system" iocsh command. Thus you can do this:
start {	exec 'system "startscript arguments"'; }
Or even this:
start { exec 'system "startscript -value=%f"'; }
Re: how to issue a shell command from EPICS record ? Dirk Zimoch
Re: how to issue a shell command from EPICS record ? Konrad, Martin
Prev: Re: Sending alarm warnings via email and text Pierrick Hanlet
Next: Re: how to issue a shell command from EPICS record ? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: how to issue a shell command from EPICS record ? Konrad, Martin
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
