1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: A question regarding sequencer compatibility
Date: Wed, 2 Oct 2013 02:36:29 +0200
Am Dienstag, 1. Oktober 2013, 17:06:16 schrieb Mooney, Tim M.:
> I'm fine with all your plans.  Personally, I would also be ok with
> just changing pvXXX so that they work as one would expect them to
> work - as pvXXXs would work.  Did you consider and reject a
> compile-time switch that would make pvXXX behave as pvXXXs?  That
> seems simpler to me.
Thanks Tim,
I haven't considered it yet. Out of reflex, probably, I usually try to
avoid adding compiler switches if possible. In this case it doesn't
sound too bad, actually. Have to think about it, thanks for the
suggestion.
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
A question regarding sequencer compatibility Benjamin Franksen
RE: A question regarding sequencer compatibility Mark Rivers
RE: A question regarding sequencer compatibility Mooney, Tim M.
Prev: Re: how to issue a shell command from EPICS record ? Johnson, Andrew N.
Next: Re: A question regarding sequencer compatibility Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: A question regarding sequencer compatibility Mooney, Tim M.
Next: Re: A question regarding sequencer compatibility J. Lewis Muir
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
