1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: procServ and sseq
To: "'Pierrick Hanlet'" <[email protected]>, "'Tech Talk'" <[email protected]>
Date: Sat, 28 Sep 2013 09:07:00 -0400
Is the Linux IOC running under the same user ID when using procServ as when running from the command line? If not, access security may be blocking writes.
Steven Hartman
[email protected]
 -----Original Message-----
Sent:	Saturday, September 28, 2013 06:28 AM Eastern Standard Time
To:	Tech Talk
Subject:	procServ and sseq
I have several soft IOCs running on different ports on a linux PC and several IOCs running on VME crates.
I'm using 3.14.11 and SL5.4.
When running one soft IOC from a command line, I can run sequences that set values in the VME IOCs.
However, when I've started the IOC from procServ, my sequences fail to change the values of the PVs
in the VME IOCs.  I did try the trick of using a pre_st.cmd file to ensure that EPICS_CA_ADDR_LIST is
properly defined.
I cannot find this problem in the archives.  Any help would be greatly appreciated.
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
Re: procServ and sseq Pierrick Hanlet
Prev: procServ and sseq Pierrick Hanlet
Next: Re: procServ and sseq Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
