1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS base Installation Error- Need Help
To: Ganesh Jangir <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 27 Sep 2013 11:08:24 +0000
Although Andrew said that not too many EPICS users run Fedora, we have been using it for many years as our primary EPICS development machine.  I know we have run at least Fedora Core 9, 14 and 15.  15 is what we are currently using.  This is the host that I use for developing many EPICS packages (asyn, areaDetector, modbus, mca, quadEM, etc.).  It is also our production machine that is used as the vxWorks boot host and to run about 20 soft IOCs.
Typically every distribution needs a few additional packages installed (readline, Motif, etc.) depending on what EPICS extensions and other modules you want to run.  This is done differently for each distribution, but I don't recall any common distributions that folks had real problems getting EPICS to build and run.
From: [email protected] [[email protected]] on behalf of Ganesh Jangir [[email protected]]
Sent: Friday, September 27, 2013 4:26 AM
To: [email protected]
Cc: [email protected]
Subject: Re: EPICS base Installation Error- Need Help
Hi Andrew,
Could you please suggest the better Operating System (open source as well as proprietary) for EPICS , CSS development.
What are the packages, we must have other than c++ complier, perl and gnu make.
Thanks and Regards
Ganesh Jangir
Tata Consultancy Services
1, Mangaldas Road,
Pune - 411001,Maharashtra
India
Ph: +91 20 66086078,
M:+918793501030, +919461552772
Mailto: [email protected]
Website: http://www.tcs.com
[email protected] wrote: -----
To: Vikas Kumthekar <[email protected]>
Sent by: [email protected]
Date: 09/24/2013 08:41PM
cc: [email protected]
Hi Vikas,
As Mark Rivers said unless you actually need the Perl bindings to CA
your copy of Base has everything else built.  It looks like you need the
fedora RPM perl-Pod-Checker to get the missing executable.
On 09/24/2013 09:40 AM, Vikas Kumthekar wrote:
> I was just wondering if, there is any installation document which will
> help for the beginners like me.
There are not many EPICS users who run Fedora, and these kinds of
problems are specific to the distribution that you're running.  There
are documents in the base/documentation directory which give some advice
on building Base, but we don't have a supply of programmers who could
test building Base and write instructions for every Linux distribution.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
Re: EPICS base Installation Error- Need Help Andrew Johnson
Re: EPICS base Installation Error- Need Help Miroslav Mihaylov
EPICS base Installation Error- Need Help Vikas Kumthekar
Re: EPICS base Installation Error- Need Help Vikas Kumthekar
Re: EPICS base Installation Error- Need Help Ganesh Jangir
Prev: Re: EPICS base Installation Error- Need Help Ganesh Jangir
Next: Re: EPICS base Installation Error- Need Help Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
