Hi folks,
Today I did some tests regarding "clean" shutdown of an IOC and found
some unsatisfying results. There seems to be no clean way of destroying
events, mutexes, or message queues, because they all cannot be destroyed
as long as there are threads waiting on them. At least that is the case
on Linux.
Example: One thread is waiting on an event. Whenever it gets signaled,
it does some work on hardware.
At exit I have do shutdown the hardware cleanly. After this time no
thread must try to use it any more. Also I better don't simply kill the
work thread while it is accessing the hardware. (And I probably do not
know all the threads involved). So I prefer to terminate while the
thread has noting to do, i.e. while it is waiting on the event.
I had expected that when I destroy the queue, all pending threads would
wake up and receive an error. This is not the case. Instead I found that
destroying the event failed with "Device or resource busy"
The same is true for mutexes as I tested. Also message queues cannot be
released like this.
Is this a bug or simply "unsupported"?
Any idea what I can do?
Dirk
- Re: cleaning up at exit and waiting threads Eric Norum
Channel Access in Erlang paper at ICALEPCS 2013 Dennis Nicklaus
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
