Thanks for your replies. I tried with yum install perl-devel readline-devel gcc-c++ re2c However, I have run into another set of errors as depicted below. Attaching the detailed error list for the reference in .pdf format. Can any one help in this.. I was just wondering if, there is any installation document which will help for the beginners like me. /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -D_REENTRANT -D_GNU_SOURCE -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/perl5/CORE Cap5.c ../Cap5.xs: In function ‘CA_put’: ../Cap5.xs:598:16: warning: ‘p.dbr’ may be used uninitialized in this function [-Wmaybe-uninitialized] status = ca_array_put(type, num_values, pch->chan, p.dbr); ^ ../Cap5.xs: In function ‘CA_put_callback’: ../Cap5.xs:691:16: warning: ‘p.dbr’ may be used uninitialized in this function [-Wmaybe-uninitialized] status = ca_array_put_callback(type, num_values, pch->chan, p.dbr, ^ /usr/bin/g++ -o libCap5.so -shared -fPIC -Wl,-hlibCap5.so -L/home/159251/Downloads/base-3.14.12.3/lib/linux-x86 -Wl,-rpath,/home/159251/Downloads/base-3.14.12.3/lib/linux-x86 -m32 Cap5.o -lca -lCom -lpthread -lreadline -lm -lrt -ldl -lgcc Installing loadable shared library ../../../lib/linux-x86/libCap5.so Installing PERL_MODULES file ../../../lib/perl/CA.pm Installing loadable shared library ../../../lib/perl/5.16.3/i386-linux-thread-multi/libCap5.so mkdir ../../../lib/perl/5.16.3 mkdir ../../../lib/perl/5.16.3/i386-linux-thread-multi Installing script ../../../bin/linux-x86/cainfo.pl Installing script ../../../bin/linux-x86/caput.pl Installing script ../../../bin/linux-x86/caget.pl Installing script ../../../bin/linux-x86/capr.pl Installing script ../../../bin/linux-x86/camonitor.pl rm -f CA.html podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html /bin/sh: podchecker: command not found make[3]: *** [CA.html] Error 127 make[3]: Leaving directory `/home/159251/Downloads/base-3.14.12.3/src/cap5/O.linux-x86' make[2]: *** [install.linux-x86] Error 2 make[2]: Leaving directory `/home/159251/Downloads/base-3.14.12.3/src/cap5' make[1]: *** [cap5.install] Error 2 make[1]: Leaving directory `/home/159251/Downloads/base-3.14.12.3/src' make: *** [src.install] Error 2 Thanks and Regards Vikas Kumthekar [email protected] wrote: ----- To: [email protected] Attachment:
EPICS_Installation_Errors.pdf
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
