1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS base Installation Error- Need Help
To: Vikas Kumthekar <[email protected]>
Cc: [email protected]
Date: Mon, 23 Sep 2013 10:26:27 -0500
Hi Vikas,
On 09/23/2013 10:03 AM, Vikas Kumthekar wrote:
I am getting following errors, while installing. Will be useful, if
someone there could help me to resolve these errors. Does anyone has a
updated installation procedure/ standard procedure for the installation.
compilation terminated.
make[3]: *** [epicsReadline.o] Error 1
make[3]: Leaving directory
`/home/159251/Desktop/Vikas/base-3.14.12.3/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory
`/home/159251/Desktop/Vikas/base-3.14.12.3/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/159251/Desktop/Vikas/base-3.14.12.3/src'
make: *** [src.install] Error 2
To be sure what the actual error is we would need to see some lines immediately above what you quoted (lines with with "error:" in them), but I'm pretty sure that the problem is that you don't have the readline-devel RPM installed. That package provides the readline.h header file which epicsReadline.c uses.
Also make sure that you have looked at the comments in the file
  configure/os/CONFIG_SITE.Common.linux-x86
about the setting for COMMANDLINE_LIBRARY value, although I think the default should work for a recent Fedora installation.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
EPICS base Installation Error- Need Help Vikas Kumthekar
Prev: EPICS base Installation Error- Need Help Vikas Kumthekar
Next: Re: EPICS base Installation Error- Need Help J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
