Emmanuel Mayssat wrote:
Let me see if I understand correctly.
You use a device like the cRIO ( http://www.ni.com/compactrio/ ) that include a FPGA.
That FPGA is running code (VHDL +) generated and downloaded through LabView.
LabVIEW can create the FPGA code but it does require a different technique than non-FPGA LabVIEW.
The FPGA is programmed for 2 functions: (1) interface with the hardware (2) run an embedded EPICS IOC.
Once the FPGA is programmed, you can interface with its process variable (PV) to change (let's say) a digital output.
No, the cRIO runs VxWorks and EPICS in the non-FPGA processor. For input the FPGA moves results from the cRIO modules to a place for run-time LabVIEW to fetch and make available via shared memory to the EPICS device support.
Now we're pretty much at the limit of what I know since I am not the implementor of this scheme. You might try googling 'fpga labview epics'.
John Faucett
LANSCE
LANL
Correspondence
- LabView interface to EPICS Emmanuel Mayssat
- Re: LabView interface to EPICS Faucett, John A
- RE: LabView interface to EPICS Emmanuel Mayssat
Re: LabView interface to EPICS Scott Baily
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
