John,
Let me see if I understand correctly.
You use a device like the cRIO (
http://www.ni.com/compactrio/ ) that include a FPGA.
That FPGA is running code (VHDL +) generated and downloaded through LabView.
The FPGA is programmed for 2 functions: (1) interface with the hardware (2) run an embedded EPICS IOC.
Once the FPGA is programmed, you can interface with its process variable (PV) to change (let's say) a digital output.
Is LabVIew only only to configure the FPGA?
Or is LabVIew also used to control the FPGA (I/O), i.e. interact with PVs ?
If that's the case, do you use Labview GUIs that interact with multiple EPICS devices or IOCs?
(That is can labview GUI be used as a replacement for edm/BOY/etc?)
Emmanuel
[email protected]To:
[email protected]Subject: Re: LabView interface to EPICS
Date: Thu, 19 Sep 2013 21:20:06 +0000
Emmanuel Mayssat wrote:
LANSCE is using this for all future generic analog and binary devices. We have 45 such production IOCs now (compared to 26 VME-based IOCs).
What are the benefit of such a setup?
Fairly good cost per channel. We can use very similar setups for most IOCs. We will convert most Camac and our home-grown RICE systems to these.
Learning LabVIEW. Learning FPGA programming. Dependence on NI. LabVIEW code is much more monolithic compared to ASCII sources (that is, files for a single application are numerous and not human-readable).
John Faucett
LANSCE
LANL
Correspondence
