Hi Matt, > In the future plans section at the end, you mentioned that all plugins will call setTimeStamp to set the plugin timestamp. > Will this be required, even if TSE!=-2? Or, if it is required, would it done automatically in the plugin base class? It is required even if TSE!=-2, because the plugin has no way of knowing what TSE is. However, it is automatically handled by the plugin base class. I have now finished the areaDetector task I discussed under the Future Plans section in the original document. I have also changed the asyn implementation by adding two new asyn shell commands. I have attached the revised document for asyn, and the new document for areaDetector. I would appreciate any comments before I release these in the next versions of asyn and areaDetector. Thanks, Mark -----Original Message----- From: Pearson, Matthew R. [mailto:[email protected]] Sent: Tuesday, September 17, 2013 8:25 AM To: Mark Rivers Subject: Re: asyn support for EPICS timestamps and records with TSE=epicsTimeEventDeviceTime Hi Mark, I read your document, and it seems like a useful addition. In the future plans section at the end, you mentioned that all plugins will call setTimeStamp to set the plugin timestamp. Will this be required, even if TSE!=-2? Or, if it is required, would it done automatically in the plugin base class? Cheers, Matt On Sep 11, 2013, at 4:46 PM, Mark Rivers <[email protected]> wrote: > <AsynTimeStampSupport.pdf> Attachment:
AsynTimeStampSupport.pdf Attachment:
areaDetectorTimeStampSupport.pdf
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
