Hi:
Local PVs cannot be read by an external application.
Access to local PVs is limited to the same CSS instance that created them.
In the latest incarnation, closing a CSS *.opi that uses "loc://pv" will actually release that "loc://pv" and the underlying pvmanager will delete it, so the next time you open that same *.opi, you start over with a new variable.
If you want to have PVs that last longer, or are network accessible (including localhost), use an EPICS soft IOC.
-Kay
On Sep 16, 2013, at 7:04 AM, Manuel Millán Álvarez <[email protected]<mailto:[email protected]>> wrote:
Good Morning
I am developing a simulation system with CSS boy. I want to read/write data values from loc PVs by using an external application.
I have a CSS boy simulation application running in a local computer. This application has an element with PV name: loc://testElement1. I have another application (written in Java with JCA-CAJ) and I want to read the PV values from this application.
Is it possible?
I think this is not possible, (I can do it using a pre-defined PV element in EPICS) but I am not sure if I can read/write values from loc PV from a program out of the .opi class.
Thank you.
Manuel Millán
Área de Ejecución
Intelligent Integration Factory S.L.
Parque Científico Tecnológico de Huelva, E2000
Pol. Industrial La Raya, Calle Caucho nº1,
21.110, Aljaraque (Huelva)
Tel: +34 959 100 389 / +34 615 176 633
www.i2factory.com<http://www.i2factory.com/>
[https://lh3.googleusercontent.com/OU9lDZtzM4ZCM82HS_xd6h11sLwEQhzF53KUzfV1qtzWrCNUdYgfn0y7BGmund4XU2zAnzGos_Jfwtis5bLE3-DRoEmV81HukO1NwcUpNmXfmoJGKfc]<http://www.i2factory.com/>
- Read local CSS BOY PV form Java Manuel Millán Álvarez
Re: RDB Archiver setup Kasemir, Kay
EPICS-R3.14.12 installation on Ubuntu-12.04-LTS x86 PC Keith Parker
<2013>
<2013>
