1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RDB Archiver setup
Date: Mon, 16 Sep 2013 10:02:21 +0000
Hello,
I am trying to use EPICS RDB archiver on Windows 7. So far I manage to prepare Configuration tool and Engine products. I have configured DB scheme “archiver“ (just for 2 PVs for now) and started the engine. Everything goes well, but the archiver does not connect to the EPICS PVs (I can see Read timeout error in the log and it is also stated by the webserver.). Does somebody have any idea what needs to be configured to enable the connection to the EPICS PVs ? I have tryed to turn off the firewalls to be sure the communication is not blocked.
I will be thankfull for any advice.
Cheers,
Mike
The log from the startup is:
c:\data\ELI Products\L1_BEAUTY_Archiver\eclipse>ArchiveEngine.exe -engine l1 -pluginCustomization l1b.ini
2013-09-16 11:40:08.975 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Archive Engine 3.2.0.201309141337
2013-09-16 11:40:09.104 INFO [Thread 1] org.csstudio.archive.engine.server.EngineServer (<init>) - Engine HTTP Server on http://localhost:4812/main
2013-09-16 11:40:09.104 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Reading configuration 'l1'
2013-09-16 11:40:09.556 CONFIG [Thread 1] org.csstudio.utility.pvmanager.epics.Epics3DataSource (<clinit>) - Loading epics data source parameters: com.cosylab.epics.caj.CAJContext - 2
2013-09-16 11:40:09.598 CONFIG [Thread 1] org.csstudio.utility.pvmanager.Activator (start) - Adding data source ca
2013-09-16 11:40:09.598 CONFIG [Thread 1] org.csstudio.utility.pvmanager.Activator (start) - Adding data source sim
2013-09-16 11:40:09.599 CONFIG [Thread 1] org.csstudio.utility.pvmanager.Activator (start) - Adding data source epics
2013-09-16 11:40:09.600 CONFIG [Thread 1] org.csstudio.utility.pvmanager.Activator (start) - Setting default data source to ca
2013-09-16 11:40:09.607 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Read configuration: 2 channels in 0.501 seconds
2013-09-16 11:40:09.607 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Running, CA addr list: 127.0.0.1
2013-09-16 11:40:09.608 INFO [Thread 1] org.csstudio.archive.engine.model.WriteThread (start) - Adjusting write period from 3 to 5
2013-09-16 11:40:09.610 INFO [Thread 27] org.csstudio.archive.engine.model.WriteThread (run) - WriteThread starts
2013-09-16 11:40:09.638 INFO [Thread 31] org.csstudio.archive.engine.scanner.ScanThread (run) - Scan Thread runs
2013-09-16 11:40:39.678 WARNING [Thread 30] org.csstudio.archive.engine.model.ArchiveChannel$1 (pvChanged) - Channel 'L1-FE-L1_1-BB-PL-RA-LH-CHL:Flow1' org.epics.pvmanager.TimeoutException: Read timeout
        at org.epics.pvmanager.PVReaderDirector$3.run(PVReaderDirector.java:317)
        at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
        at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
        at java.util.concurrent.FutureTask.run(Unknown Source)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
        at java.lang.Thread.run(Unknown Source)
2013-09-16 11:40:39.678 WARNING [Thread 28] org.csstudio.archive.engine.model.ArchiveChannel$1 (pvChanged) - Channel 'L1-FE-L1_1-BB-PL-RA-LH-CHL:Outlet_Temperature' org.epics.pvmanager.TimeoutException: Read timeout
Re: RDB Archiver setup Jack
Re: RDB Archiver setup Kasemir, Kay
Prev: ASYN on BeagleBone ARM Amien Crombie
Next: RE: ASYN on BeagleBone ARM Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: ASYN on BeagleBone ARM Emmanuel Mayssat
Next: Re: RDB Archiver setup Jack
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
