1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: BiRa Ethernet Power Supply Controllers
To: "'Rod Nussbaumer'" <[email protected]>, epics Techtalk <[email protected]>
Date: Thu, 12 Sep 2013 12:44:47 -0700
Hi Rod,
At SPEAR, we use the EPSCs for our main power supplies (unipolar power supplies for quads, bends, etc, that don't need fast control).  The EPICS driver/device support is a bit non-standard (ie, doesn't use asyn - note the controller uses UDP) but works OK, at least on epics 3.14.11, RHEL6-64bit.  The software we use is here in case you want to take a look:
ftp://ftp.slac.stanford.edu/groups/controls/soft/epics/etherPSC.tar.gz
Sorry - there is no documentation in that tar file.  Maybe BiRa provides some documentation.
(I don't know if this is the same software that BiRa provides).
I will forward your email to the SPEAR power supply engineer who can fill you in on more detail.
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Rod Nussbaumer
> Sent: Wednesday, September 11, 2013 4:39 PM
> To: epics Techtalk
> Subject: BiRa Ethernet Power Supply Controllers
> Hi all.
> Has anyone had any exeprience with BiRa Ethernet Power Supply
> Controllers? BiRa is advertising that SLAC has used them, so I would be
> happy to hear from anyone there with some firsthand knowledge.
> What is the nature of the EPICS support? Being ethernet, I was hoping
> for something SCPI-like, but the datasheet doesn't suggest that.
> Our power supply group would also like to contact anyone that may have
> knowledge of the hardware, installation, and those aspects of these devices.
> Thanks.
> Rod Nussbaumer
> ISAC Controls, TRIUMF
> Vancouver, Canada.
Re: BiRa Ethernet Power Supply Controllers Rod Nussbaumer
Prev: RE: BiRa Ethernet Power Supply Controllers Emmanuel Mayssat
Next: RE: EtherCAT and NI slave chassis [SEC=UNCLASSIFIED] LYNCH, Damien
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: BiRa Ethernet Power Supply Controllers Rod Nussbaumer
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
