1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: motor record: soft motor & DMOV
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 10 Sep 2013 19:32:22 +0000
Hello Mark,
> What about changing your calcout record so that is still CP on DMOV,
> but it writes 1 to the output whenever DMOV is 1.  Then you are not
> limiting yourself to transitions (which you might have missed), but
> you are saying "whenever DMOV changes and is 1 set the output gate".
This works indeed :-) At least it passed all test cases I have put
together so far...
Thanks a lot.
Martin
P.S.: For everyone that runs into the same issue I attach the complete
implementation of the DMOV logic I have between the hard and soft motor
records. Maybe it makes sense to add this to the motor record website.
Attachment: done moving logic for multi-axis motor setups with hard and soft motors.png
Description: done moving logic for multi-axis motor setups with hard and soft motors.png
Re: motor record: soft motor & DMOV Konrad, Martin
Prev: Re: Multiple patterns/ .sub files for the same .db file Andrew Johnson
Next: Re: race condition with calcout & CA input links? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: motor record: soft motor & DMOV Mark Rivers
Next: New edm widgets Young, James R.
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
