Hi Tito,
On 09/10/2013 12:06 PM, Tito Körner wrote:
I have .sub file looking like this:
file "hvtest.db"
pattern {PROTO, P, BOXNO, LEVELNO, CHANNELNO, ELEMENTNO}
{hvtest.proto, HV, 19, 0, 0, 0}
{hvtest.proto, HV, 19, 0, 1, 1}
Now I would need another pattern in the same .db file looking like this:
file "hvtest.db"
pattern {EELO, EEUP}
{dhcp, DHCP}
{ip, IP}
I tried two dbLoadTemplate - lines in my .cmd file
dbLoadTemplate "a.sub"
dbLoadTemplate "b.sub"
but I then got Error messages saying the substitutions from the first
file are undefined. I also tried to put both patterns in one file (I
found examples with different patterns for different .db files). But
then again I get error messages saying the substitutions are undefined.
When I directly append the second pattern after the first, I get a
syntax error message. So how can this be done?
Your examples above do not make sense for template substitutions; does
the hvtest.db template file use macros named PROTO, P, BOXNO etc, or
EELO and EEUP, or all of them? If it has all of them you will need to
combine the macro values, but I don't know exactly how -- this might be
one way although I suspect it's wrong:
file "hvtest.db"
pattern {PROTO, P, BOXNO, LEVELNO, CHANNELNO, ELEMENTNO, EELO, EEUP}
{hvtest.proto, HV, 19, 0, 0, 0, dhcp, DHCP}
{hvtest.proto, HV, 19, 0, 1, 1, dhcp, DHCP}
{hvtest.proto, HV, 19, 0, 0, 0, ip, IP}
{hvtest.proto, HV, 19, 0, 1, 1, ip, IP}
If I've misunderstood what you're trying to do you might need to include
a snippet from the hvtest.db file as well for us to understand your
question properly.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Multiple patterns/ .sub files for the same .db file Tito Körner
Re: motor record: soft motor & DMOV Konrad, Martin
<2013>
RE: Multiple patterns/ .sub files for the same .db file Emmanuel Mayssat
<2013>
