On 5/30/13 5:32 PM, J. Lewis Muir wrote:
> On 5/30/13 3:06 PM, J. Lewis Muir wrote:
>> Using nfsstat on the NFS server, I can confirm that the IOC NFS client
>> is using NFSv3. Yes, if you'd be willing, I would love it if you could
>> send that image! I'd like to try that to see if it helps.
> Hi, Andrew.
> Thanks for the image. After booting with the new image, I've confirmed
> the IOC NFS client is using NFSv2 now. And 'ls' works. Now I'll just
> wait and see if the RPC problem comes up again.
Hi, Andrew.
Just following up to let you know that I have had no problems since
making this change.
It would be great if the root cause could be tracked down and fixed, or
if there was a way to easily configure whether to use NFSv2 or NFSv3, or
I'd even be fine with always using NFSv2, but I don't know if others
feel the same way.
Lewis
- Re: autosave failure S_rpcLib_RPC_CANTSEND Ron Sluiter
- Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
- autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
- Re: autosave failure S_rpcLib_RPC_CANTSEND Andrew Johnson
RE: Motor field "UEIP" cause austen.rose
RE: EhterCAT terminals [SEC=UNOFFICIAL] ronaldo.mercado
<2013>
<2013>
