Hi Jim,
On 08/29/2013 10:18 AM, Jim Chen wrote:
make -C ./cap5 install
make[2]: Entering directory `/home/root/R3.14.12.3/base/src/cap5'
perl ../../bin/linux-arm/makeMakefile.pl O.linux-arm ../../..
mkdir O.Common
make -C O.linux-arm -f ../Makefile TOP=../../.. T_A=linux-arm install
make[3]: Entering directory `/home/root/R3.14.12.3/base/src/cap5/O.linux-arm'
rm -f Cap5.c Cap5.c_new
perl /usr/lib/perl/5.14.2/ExtUtils/xsubpp -typemap /usr/lib/perl/5.14.2/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
Can't open perl script "/usr/lib/perl/5.14.2/ExtUtils/xsubpp": No such file or directory
Martin Konrad's point about a missing Perl package is right, this script
normally comes with the standard Perl distribution but many Linux
distributions have taken to splitting up Perl into multiple packages and
only installing some of them by default.
However unless you are planning to make use of the Perl CA library on
this system you can ignore this error, it is only needed to let Perl
programs talk to the Channel Access client library. The src/cap5
subdirectory is the last one that gets built in base 3.14 so your
installation should be fully working apart from the Perl bindings to CA.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- RE: Build problem of EPICS R3.14.12.3 for ARM processor in Linux Jim Chen
- Ipac driver 2.12 now available Andrew Johnson
- Build problem of EPICS R3.14.12.3 for ARM processor in Linux Jim Chen
Re: motor record: soft motor & DMOV Konrad, Martin
Re: Hardware simulator Ralph Lange
<2013>
<2013>
