Hi Kevin,
> When a soft motor is commanded to move, it is the motor record that
> initially set the DMOV to zero; the value of DINP PV is ignored at
> this point. The first time the DINP PV is used is the first status
> update after the move is initiated. If the moving-poll rate of the
> real motors is high,
60 Hz in my case
> there can be a very narrow window during which the DINP calc must be
> done.
Sorry, I don't get it, yet. Can you please describe a bit more detailed
how it is supposed to behave and in contrast to that what you think
happens if it fails?
> In "soft motor record.db" the DINP field is set to
> "$(PREFIX):doneMoving_". How is $(PREFIX):doneMoving_ calculated?
record(calc, "$(PREFIX):doneMoving_") {
field(CALC, "A && B")
field(INPA, "$(PREFIX):motorRadPiston.DMOV CP MS")
field(INPB, "$(PREFIX):doneMovingGate_ NPP MS")
record(bo, "$(PREFIX):doneMovingGate_") {
field(FLNK, "$(PREFIX):doneMoving_")
record(calcout, "$(PREFIX):doneMovingCloseGate_") {
field(CALC, "A")
field(INPA, "$(PREFIX):motorAngPiston.DMOV CP MS")
field(OUT, "$(PREFIX):doneMovingGate_ PP MS")
field(OOPT, "Transition To Non-zero")
field(DOPT, "Use OCAL")
field(OCAL, "1")
This is inspired by a mail by Tim
(http://www.aps.anl.gov/epics/tech-talk/2008/msg00127.php). I hope I
implemented it the right way...
Martin
- Re: motor record: soft motor & DMOV Ron Sluiter
- Re: motor record: soft motor & DMOV Kevin Peterson
- motor record: soft motor & DMOV Konrad, Martin
- RE: motor record: soft motor & DMOV Mooney, Tim M.
<2013>
<2013>
