1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: streamdevice to find the last match
To: Dirk Zimoch <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 27 Aug 2013 16:51:24 -0700
Hi Dirk and Wesley,
Thank you very much for your helps!
I was not very sure whether I could, and how to, use the "$" anchor.  Your suggestions
made me try again -- it works!  Now my protocol is like:
STATUS  { ReplyTimeout = 50; ReadTimeout = 10; InTerminator =; in "%.1/BOS([0-9,P=\-]*EOS)\r\n$/"; }
Because I have
InTerminator =;
streamdevice will not remove the "\r\n".  The end of my string is really "EOS\r\n".
Thank you again, best regards,
Dehong
Sent: Friday, August 23, 2013 7:11 AM
To: Zhang, Dehong
Cc: [email protected]
Subject: Re: streamdevice to find the last match
Dehong,
I am not sure if the payload data is the first number or the P= number
or both.
In any case with a %*/.*BOS*/ you should be able to find the last BOS in
your input. After that start reading your data. If P= is your data it
would look like this:
in "%*/.*BOS/*d,P=%dEOS\r\n";
BTW: ExtraInput = Ignore is almost always a bad idea. Use it only if
absolutely necessary.
Dirk
On 23.08.2013 09:55, Dirk Zimoch wrote:
> Hello Dehong,
> Is your record "I/O Intr"? I assume so because your STATUS protocol does
> not have any out command.
> In that case and if you set InTerminator = CR LF, you should actually
> get 2 messages and the record should be processed twice. Thus at the
> end, your record will have the correct value.
> Skipping intermediate results is tricky on the protocol level, because
> how should StreamDevice know that no more input is about to come? What
> if the gap between the messages is sometimes so big, that you actually
> get 2 messages?
> But In case you really always get a double message as below and want to
> read the second value only you can skip the first one:
> in "BOS%*d,P=%*dEOS\r\nBOS%d,P=%(otherrecord)dEOS\r\n"
> In case you may have an arbitrary number of messages connected and
> always want to skip all but the last, things become tricky. I have to
> make up a PCRE. The idea is to do a greedy search for everything up to
> "BOS" and then read the data. I will send you the PCRE later.
> Dirk
> On 22.08.2013 21:17, Zhang, Dehong wrote:
>> Hi Dirk and Friends,
>> (Sorry if you get this 2 times. I had a wrong address with my previous
>> send)
>> I run into 2 little problems: I wait for the hardware to send a
>> message like
>> "BOS123456,P=987654EOS\r\n".
>> Here BOS is my starting label and EOS the ending label.
>> Due to timing, which I cannot control, sometimes I would receive 2
>> messages
>> together, like:
>> "BOS123456,P=987654EOS\r\nBOS345,P=987649EOS\r\n".
>> Here the first one was sent when the state was still changing, the
>> second one
>> was sent when the state stablizes. But the time in between is so short
>> that the
>> 2 messages just come out as one. How can I skip the first match, only
>> get the
>> second/last match?
>> My protocal is like:
>> InTerminator = CR;
>> OutTerminator = CR LF;
>> ReplyTimeout = 800;
>> ReadTimeout = 100;
>> WriteTimeout = 100;
>> ExtraInput = Ignore;
>> # Reports from the controller
>> "%.1/BOS([0-9,P=]*EOS)/"; }
>> I tried to use the "$" anchor, but cannot get it to work -- maybe
>> because "$" is a special
>> character in streamdevice.
>> Related to this, sometimes the time in between is not so short that
>> the 2 messages
>> do come out separately, but the time in between is short enough so
>> that my stringin
>> record misses the second message. How can I avoid this? Tune the
>> ReplyTimeout,
>> ReadTimeout and InTerminator?
>> Thank you for your advice. Best regards,
>> Dehong
streamdevice to find the last match Zhang, Dehong
Re: streamdevice to find the last match Dirk Zimoch
Prev: New edm widgets Young, James R.
Next: has anyone used ipc-100 of ADVANTECH company as softioc? Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: streamdevice to find the last match Dirk Zimoch
Next: Problems compiling Nexus library as DLL on Windows Mark Rivers
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
