Hello,
I am using Streamdevice (
http://epics.web.psi.ch/software/streamdevice/doc/index.html) to control a
high voltage box. The box has 5 levels with 8 channels each, so it controls
40 channels. The boxes receive commands and send output via telnet.
Currently I only have two records - one for reading one for writing values.
To access all channels I use a template. The problem is whenever I give one
channel the command to change the value - the entire traffic gets mixed up:
My .db looks like this:
record (stringout, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):set_volt")
field (DTYP, "stream")
field (OUT, "@$(PROTO) set_voltage($(LEVELNO),$(CHANNELNO))
termBox$(BOXNO)")
record (ai, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):read_volt")
field (INP, "@$(PROTO) read_voltage($(LEVELNO),$(CHANNELNO))
termBox$(BOXNO)")
field (SCAN, "1 second")
field (FLNK, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):read_volt")
field (PACT, "")
field (STAT, "")
field (SEVR, "")
field (VAL, "")
My protocol file looks like this:
terminator = CR LF;
LockTimeout = 10000;
read_voltage {
out "read_adc floats_csv \$1 \$2";
in "%*d.%*d.%*d %*d:%*d:%*d,%f";
@mismatch{out "read_adc floats_csv \$1 \$2"; in "%*d.%*d.%*d
%*d:%*d:%*d,%f";}
set_voltage {
out "SetVpmF \$1 \$2 %s";
in "DAC: \$1 CH: \$2 U: %*f Uk: %*f";
in "Nachregelung aktiv!";
in "Messwert: %*f DAC: \$1 CH: \$2 Value: %*f korrigiert: %*f";
I created a python script that prints all values to the terminal. As long
as only the read record is activ everything works out. But when I use
another terminal to set a voltage like: 'caput
CB:HV:BOX:19:0:0:1480:set_volt' the voltage values start to 'jump around'.
I monitored the network traffic with wireshark and saw this:
read_adc floats_csv 2 5
01.01.1900 04:23:55,1345.003
read_adc floats_csv 2 6
01.01.1900 04:23:55,1345.123
read_adc floats_csv 2 7
01.01.1900 04:23:55,1345.156
read_adc floats_csv 3 0
01.01.1900 04:23:56,1346.075
read_adc floats_csv 3 1
01.01.1900 04:23:56,1343.827
read_adc floats_csv 3 2
01.01.1900 04:23:56,1376.977
read_adc floats_csv 3 3
01.01.1900 04:23:56,1346.537
read_adc floats_csv 3 4
01.01.1900 04:23:56,1341.462
read_adc floats_csv 3 5
01.01.1900 04:23:56,1368.079
SetVpmF 0 0 1480
*read_adc floats_csv 3 6 *
DAC: 0 CH: 0 U: 1480.000 Uk: 1584.800
Nachregelung aktiv!
Messwert: 1479.545 DAC: 0 CH: 0 Value: 1480.350 korrigiert:
1585.165
Messwert: 1479.941 DAC: 0 CH: 0 Value: 1480.395 korrigiert:
1585.212
Messwert: 1479.935 DAC: 0 CH: 0 Value: 1480.445 korrigiert:
1585.264
Messwert: 1480.045 DAC: 0 CH: 0 Value: 1480.410 korrigiert:
1585.228
Messwert: 1480.046 DAC: 0 CH: 0 Value: 1480.375 korrigiert:
1585.191
Messwert: 1479.941 DAC: 0 CH: 0 Value: 1480.420 k*read_adc
floats_csv 3 6 *
orrigiert: 1585.238
Messwert: 1480.052 DAC: 0 CH: 0 Value: 1480.379 korrigiert:
1585.196
Messwert: 1479.963 DAC: 0 CH: 0 Value: 1480.408 korrigiert:
1585.226
Messwert: 1480.063 DAC: 0 CH: 0 Value: 1480.359 korrigiert:
1585.175
Messwert: 1479.963 DAC: 0 CH: 0 Value: 1480.388 korrigiert:
1585.205
read_adc floats_csv 3 7
01.01.1900 04:23:59,1344.063
read_adc floats_csv 4 0
01.01.1900 04:23:59,1344.070
read_adc floats_csv 4 1
01.01.1900 04:23:59,1346.169
read_adc floats_csv 4 2
01.01.1900 04:23:59,1357.607
read_adc floats_csv 0 0
01.01.1900 04:24:00,1352.217
read_adc floats_csv 0 1
01.01.1900 04:24:00,1340.962
As you can see (marked bold) in between the command 'SetVpmF 0 0 1480' and
the response from the box there are two out commands from the read_volt
record. The problem now is - the first response from the box after the
response to the set_voltage command is '01.01.1900 04:23:59,1344.06. This
is actually the voltage value belonging to the command 'read_adc floats_csv
3 6'. But because the read_volt record sent this command in between the
command and response of the set_volt record, Epics 'thinks' this is the
value for 3 7. At the StreamDevice website it says that a protocols first
out command locks the device for exclusive access until the protocol is
finished. But here this does not seem to work because obviously the
read_volt record sends the out command of its protocol while the protocol
called in the set_volt record is active. I hope someone can help me to
figure out what's going wrong and how to fix it.
Tito Koerner
