1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: StreamDevice communication problems
To: Tito Körner <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 26 Aug 2013 18:25:46 +0000
There is something I don't understand about your database.  The read_volt record is scanned a "1 second".  But it also has a forward link (FLNK) to itself?  That seems strange.  Why are you doing that?
From: [email protected] [[email protected]] on behalf of Tito Körner [[email protected]]
Sent: Monday, August 26, 2013 10:33 AM
To: [email protected]
Subject: StreamDevice communication problems
Hello,
I am using Streamdevice (http://epics.web.psi.ch/software/streamdevice/doc/index.html) to control a high voltage box. The box has 5 levels with 8 channels each, so it controls 40 channels. The boxes receive commands and send output via telnet. Currently I only have two records - one for reading one for writing values. To access all channels I use a template. The problem is whenever I give one channel the command to change the value - the entire traffic gets mixed up:
My .db looks like this:
record (stringout, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):set_volt")
    field (DTYP, "stream")
    field (OUT,  "@$(PROTO) set_voltage($(LEVELNO),$(CHANNELNO)) termBox$(BOXNO)")
record (ai, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):read_volt")
    field (INP, "@$(PROTO) read_voltage($(LEVELNO),$(CHANNELNO)) termBox$(BOXNO)")
    field (SCAN, "1 second")
    field (FLNK, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):read_volt")
    field (PACT, "")
    field (STAT, "")
    field (SEVR, "")
    field (VAL, "")
My protocol file looks like this:
terminator = CR LF;
LockTimeout = 10000;
read_voltage {
    out "read_adc floats_csv \$1 \$2";
    in "%*d.%*d.%*d %*d:%*d:%*d,%f";
    @mismatch{out "read_adc floats_csv \$1 \$2";  in "%*d.%*d.%*d %*d:%*d:%*d,%f";}
set_voltage {
    out "SetVpmF \$1 \$2 %s";
    in "DAC: \$1   CH: \$2   U: %*f  Uk: %*f";
    in "Nachregelung aktiv!";
    in "Messwert: %*f   DAC: \$1   CH: \$2   Value: %*f   korrigiert: %*f";
I created a python script that prints all values to the terminal. As long as only the read record is activ everything works out. But when I use another terminal to set a voltage like: 'caput CB:HV:BOX:19:0:0:1480:set_volt' the voltage values start to  'jump around'. I monitored the network traffic with wireshark and saw this:
> read_adc floats_csv 2 5
01.01.1900 04:23:55,1345.003
> read_adc floats_csv 2 6
01.01.1900 04:23:55,1345.123
> read_adc floats_csv 2 7
01.01.1900 04:23:55,1345.156
> read_adc floats_csv 3 0
01.01.1900 04:23:56,1346.075
> read_adc floats_csv 3 1
01.01.1900 04:23:56,1343.827
> read_adc floats_csv 3 2
01.01.1900 04:23:56,1376.977
> read_adc floats_csv 3 3
01.01.1900 04:23:56,1346.537
> read_adc floats_csv 3 4
01.01.1900 04:23:56,1341.462
> read_adc floats_csv 3 5
01.01.1900 04:23:56,1368.079
> SetVpmF 0 0 1480
read_adc floats_csv 3 6
DAC: 0   CH: 0   U: 1480.000  Uk: 1584.800
Nachregelung aktiv!
Messwert: 1479.545   DAC: 0   CH: 0   Value: 1480.350   korrigiert: 1585.165
Messwert: 1479.941   DAC: 0   CH: 0   Value: 1480.395   korrigiert: 1585.212
Messwert: 1479.935   DAC: 0   CH: 0   Value: 1480.445   korrigiert: 1585.264
Messwert: 1480.045   DAC: 0   CH: 0   Value: 1480.410   korrigiert: 1585.228
Messwert: 1480.046   DAC: 0   CH: 0   Value: 1480.375   korrigiert: 1585.191
Messwert: 1479.941   DAC: 0   CH: 0   Value: 1480.420   kread_adc floats_csv 3 6
orrigiert: 1585.238
Messwert: 1480.052   DAC: 0   CH: 0   Value: 1480.379   korrigiert: 1585.196
Messwert: 1479.963   DAC: 0   CH: 0   Value: 1480.408   korrigiert: 1585.226
Messwert: 1480.063   DAC: 0   CH: 0   Value: 1480.359   korrigiert: 1585.175
Messwert: 1479.963   DAC: 0   CH: 0   Value: 1480.388   korrigiert: 1585.205
> read_adc floats_csv 3 7
01.01.1900 04:23:59,1344.063
> read_adc floats_csv 4 0
01.01.1900 04:23:59,1344.070
> read_adc floats_csv 4 1
01.01.1900 04:23:59,1346.169
> read_adc floats_csv 4 2
01.01.1900 04:23:59,1357.607
> read_adc floats_csv 0 0
01.01.1900 04:24:00,1352.217
> read_adc floats_csv 0 1
01.01.1900 04:24:00,1340.962
As you can see (marked bold) in between the command 'SetVpmF 0 0 1480' and the response from the box there are two out commands from the read_volt record. The problem now is - the first response from the box after the response to the set_voltage command is '01.01.1900 04:23:59,1344.06. This is actually the voltage value belonging to the command 'read_adc floats_csv 3 6'. But because the read_volt record sent this command in between the command and response of  the set_volt record, Epics 'thinks' this is the value for 3 7. At the StreamDevice website it says that a protocols first out command locks the device for exclusive access until the protocol is finished. But here this does not seem to work because obviously the read_volt record sends the out command of its protocol while the protocol called in the set_volt record is active. I hope someone can help me to figure out what's going wrong and how to fix it.
Tito Koerner
StreamDevice communication problems Tito Körner
Prev: RE: ICALEPCS Agenda - Emmanuel Mayssat
Next: Re: StreamDevice communication problems Fabian S.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: StreamDevice communication problems Tito Körner
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
