1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Segmentation fault et_wish
To: [email protected]
Date: Mon, 26 Aug 2013 09:36:36 +0200
Hello Nalaka,
I do not know if this causes your problem, but some recent implementations of Tcl have a "feature" to be "thread aware". The idea was to make sure that different posix threads cannot confuse the inherently single threaded Tcl interpreter. However a side effect I have seen was that CA monitors did not work any more as expected because the monitor callback runs in a different thread.
I have first seen this behavior in Tcl 8.4. There you could have the option to compile the interpreter "not thread aware". But at least Redhad used the "thread aware" variant in their distribution. With Tcl 8.5 I got the impression things went worse but I am sot sure about this.
However, I have not seen this "feature" to segvfault the interpreter, only not to serve monitor updates.
Dirk
On 25.08.2013 09:03, nalaka samarasinghe wrote:
Hi All,
I am using et_wish for control system implementation and I wrote a small
application to display temperature reading on a label widget. It displays
the temperature but does not get updated realtime.
I have copied the tcl tk program below. Please help me to diagnose the
problem with the below code.
Many thanks,
Nalaka
Code :
wm geometry . 360x150+200+100
pv linkw temp temp_val1
pv umon temp change
label .l1 -font {Helvetica 16}  -text " $temp"
#button .btnchange -text change -command {change} -font { -size 15}
grid .l1 -row 0  -column 0
#grid .btnchange -row 1 -column 0
#label .l1 -font {Helvetica 16} -width 10 -textvariable temp
proc change {} {
  global temp
.1l configure -text "$temp"
Re: Segmentation fault et_wish Dirk Zimoch
Segmentation fault et_wish nalaka samarasinghe
Prev: Segmentation fault et_wish nalaka samarasinghe
Next: Re: Segmentation fault et_wish Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
