1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problems compiling Nexus library as DLL on Windows
Cc: Jan Ilavsky <[email protected]>, "'Mark Koennecke'" <[email protected]>, "Schwarz, Nicholas" <[email protected]>, "Madden, Timothy J." <[email protected]>, "'Glowacki, Arthur T.'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 23 Aug 2013 08:50:49 -0500
Hi Mark,
On 08/22/2013 10:21 PM, Mark Rivers wrote:
The problem is that when H5Tpublic.h is being included the macro
H5_DLLVAR is not correctly defined to be "__declspec(dllimport)".
Rather H5_DLLVAR appears to be defined as "extern".  This causes the
linker to be unable to locate these symbols, even though they are
correctly exported by the .lib file.
I just need to figure out why H5_DLLVAR is not being correctly
defined in H5api_adpt.h.  It looks like it should be, but clearly I
am doing something wrong.
Decorators like that are a common issue with Windows builds, EPICS has the epicsShare* macros defined in shareLib.h which on Windows expand to __declspec(dllimport) when calling the relevant symbol from a DLL, __declspec(dllexport) when building the DLL, or to nothing when building or calling a static library.
You may have to add a command-line argument to the compiler to define some symbol that tells the header whether the Nexus library is being built as a DLL, or being called in one. Look in the header that defines H5_DLLVAR and compare what it's doing with what shareLib.h does.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
RE: Problems compiling Nexus library as DLL on Windows Mark Rivers
Prev: Re: streamdevice to find the last match Wesley Moore
Next: RE: Problems compiling Nexus library as DLL on Windows Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Problems compiling Nexus library as DLL on Windows Mark Rivers
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
