1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: streamdevice to find the last match
To: Dehong Zhang <[email protected]>
Cc: [email protected]
Date: Fri, 23 Aug 2013 09:20:54 -0400 (EDT)
Hey Dehong,
I was thinking along the lines of Dirk's response (leave InTerminator = CR LF).  However, leaving InTerminator=; have you tried using @mismatch to instead parse the double message?
Wesley
----- Original Message -----
> From: "Dirk Zimoch" <[email protected]>
> To: "Dehong Zhang" <[email protected]>
> Sent: Friday, August 23, 2013 3:55:37 AM
> Hello Dehong,
> Is your record "I/O Intr"? I assume so because your STATUS protocol
> does
> not have any out command.
> In that case and if you set InTerminator  = CR LF, you should
> actually
> get 2 messages and the record should be processed twice. Thus at the
> end, your record will have the correct value.
> Skipping intermediate results is tricky on the protocol level,
> because
> how should StreamDevice know that no more input is about to come?
> What
> if the gap between the messages is sometimes so big, that you
> actually
> get 2 messages?
> But In case you really always get a double message as below and want
> to
> read the second value only you can skip the first one:
> in "BOS%*d,P=%*dEOS\r\nBOS%d,P=%(otherrecord)dEOS\r\n"
> In case you may have an arbitrary number of messages connected and
> always want to skip all but the last, things become tricky. I have to
> make up a PCRE. The idea is to do a greedy search for everything up
> to
> "BOS" and then read the data. I will send you the PCRE later.
> Dirk
> On 22.08.2013 21:17, Zhang, Dehong wrote:
> > Hi Dirk and Friends,
> > (Sorry if you get this 2 times.  I had a wrong address with my
> > previous send)
> > I run into 2 little problems: I wait for the hardware to send a
> > message like
> > "BOS123456,P=987654EOS\r\n".
> > Here BOS is my starting label and EOS the ending label.
> > Due to timing, which I cannot control, sometimes I would receive 2
> > messages
> > together, like:
> > "BOS123456,P=987654EOS\r\nBOS345,P=987649EOS\r\n".
> > Here the first one was sent when the state was still changing, the
> > second one
> > was sent when the state stablizes.  But the time in between is so
> > short that the
> > 2 messages just come out as one.  How can I skip the first match,
> > only get the
> > second/last match?
> > My protocal is like:
> > InTerminator  = CR;
> > OutTerminator = CR LF;
> > ReplyTimeout  = 800;
> > ReadTimeout   = 100;
> > WriteTimeout  = 100;
> > ExtraInput    = Ignore;
> > # Reports from the controller
> > STATUS  { ReplyTimeout = 50; ReadTimeout = 10; InTerminator =; in
> > "%.1/BOS([0-9,P=]*EOS)/"; }
> > I tried to use the "$" anchor, but cannot get it to work -- maybe
> > because "$" is a special
> > character in streamdevice.
> > Related to this, sometimes the time in between is not so short that
> > the 2 messages
> > do come out separately, but the time in between is short enough so
> > that my stringin
> > record misses the second message.  How can I avoid this?  Tune the
> > ReplyTimeout,
> > ReadTimeout and InTerminator?
> > Thank you for your advice.  Best regards,
> > Dehong
Re: streamdevice to find the last match Dirk Zimoch
Prev: Re: Asyn AutoConnect and stream device on a soft IOC Dirk Zimoch
Next: Re: Problems compiling Nexus library as DLL on Windows Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: streamdevice to find the last match Dirk Zimoch
Next: Re: streamdevice to find the last match Dirk Zimoch
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
