Subject: |
RE: Problems compiling Nexus library as DLL on Windows |
Mark Rivers <[email protected]> |
To: |
Pete R Jemian <[email protected]>, Jan Ilavsky <[email protected]>, "'Mark Koennecke'" <[email protected]>, "Madden, Timothy J." <[email protected]>, "'[email protected]'" <[email protected]>, "'[email protected]'" <[email protected]>, "'Glowacki, Arthur T.'" <[email protected]>, "Schwarz, Nicholas" <[email protected]> |
Cc: |
"[email protected]" <[email protected]> |
Date: |
Fri, 23 Aug 2013 03:21:02 +0000 |
I have identified the problem, but have not solved it.
The file H5Tpublic.h contains definitions like the following:
H5_DLLVAR hid_t H5T_NATIVE_UINT32_g;
The problem is that when H5Tpublic.h is being included the macro H5_DLLVAR is not correctly defined to be "__declspec(dllimport)". Rather H5_DLLVAR appears to be defined as "extern". This causes the linker to be unable to locate these symbols, even though they are correctly exported by the .lib file.
I just need to figure out why H5_DLLVAR is not being correctly defined in H5api_adpt.h. It looks like it should be, but clearly I am doing something wrong.
Sent: Thursday, August 22, 2013 2:56 PM
To: Pete R Jemian; Jan Ilavsky; 'Mark Koennecke'; Madden, Timothy J.; '[email protected]'; '[email protected]'; 'Glowacki, Arthur T.'; Schwarz, Nicholas
Cc: [email protected]
Subject: Problems compiling Nexus library as DLL on Windows
Folks,
The EPICS areaDetector software has been successfully using the HDF5 library (1.8.7) on Windows since R1-7, about 2 years ago. However, only the statically linked version of the library was installed, which meant that areaDetector applications needed to be statically linked.
I am now writing a driver that must be dynamically linked, because it uses the Microsoft Common Library Runtime (/clr switch on linker). So I want to also install and use the dynamic version of the HDF5 library. I installed the dynamic versions of the required .lib files from HDF5-1.8.7_CMake_x64_shared.zip, from the HDF Web site.
When I try to build the ADApp\nexusSrc directory it compiles fine, but I get these errors it tries to link the DLL. Does anyone know what I am doing wrong?
J:\epics\devel\areaDetector\ADApp\nexusSrc>make
make -C O.windows-x64-dynamic -f ../Makefile TOP=../../.. T_A=windows-x64-dynamic install
make[1]: Entering directory `J:/epics/devel/areaDetector/ADApp/nexusSrc/O.windows-x64-dynamic'
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref /release /MACHINE:X64 /implib:NeXus.lib /out:NeXus.dll napi.obj napi5.obj napiu.obj nxdataset.obj nxio.obj nxstack.obj nxxml.obj stptok.obj ..\\..\\..\\lib\\windows-x64-dynamic\\hdf5.lib ..\\..\\..\\lib\\windows-x64-dynamic\\libszip.lib ..\\..\\..\\lib\\windows-x64-dynamic\\zlib.lib
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_SHORT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT32_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT8_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT64_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_USHORT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UCHAR_g
napi5.obj : error LNK2001: unresolved external symbol H5P_CLS_DATASET_CREATE_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_SCHAR_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_FLOAT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT8_g
napi5.obj : error LNK2001: unresolved external symbol H5T_C_S1_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT16_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT16_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT32_g
napi5.obj : error LNK2001: unresolved external symbol H5P_CLS_FILE_ACCESS_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT64_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_DOUBLE_g
NeXus.dll : fatal error LNK1120: 19 unresolved externals
make[1]: *** [NeXus.dll] Error 1120
make[1]: Leaving directory `J:/epics/devel/areaDetector/ADApp/nexusSrc/O.windows-x64-dynamic'
make: *** [install.windows-x64-dynamic] Error 2
- Re: Problems compiling Nexus library as DLL on Windows Andrew Johnson
- Problems compiling Nexus library as DLL on Windows Mark Rivers
RE: Asyn AutoConnect and stream device on a soft IOC Mark Rivers
Re: streamdevice to find the last match Dirk Zimoch
<2013>
Re: Problems compiling Nexus library as DLL on Windows Timothy Madden
<2013>
