1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: streamdevice to find the last match
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 22 Aug 2013 12:17:37 -0700
Hi Dirk and Friends,
(Sorry if you get this 2 times.  I had a wrong address with my previous send)
I run into 2 little problems: I wait for the hardware to send a message like
"BOS123456,P=987654EOS\r\n".
Here BOS is my starting label and EOS the ending label.
Due to timing, which I cannot control, sometimes I would receive 2 messages
together, like:
"BOS123456,P=987654EOS\r\nBOS345,P=987649EOS\r\n".
Here the first one was sent when the state was still changing, the second one
was sent when the state stablizes.  But the time in between is so short that the
2 messages just come out as one.  How can I skip the first match, only get the
second/last match?
My protocal is like:
InTerminator  = CR;
OutTerminator = CR LF;
ReplyTimeout  = 800;
ReadTimeout   = 100;
WriteTimeout  = 100;
ExtraInput    = Ignore;
# Reports from the controller
STATUS  { ReplyTimeout = 50; ReadTimeout = 10; InTerminator =; in "%.1/BOS([0-9,P=]*EOS)/"; }
I tried to use the "$" anchor, but cannot get it to work -- maybe because "$" is a special
character in streamdevice.
Related to this, sometimes the time in between is not so short that the 2 messages
do come out separately, but the time in between is short enough so that my stringin
record misses the second message.  How can I avoid this?  Tune the ReplyTimeout,
ReadTimeout and InTerminator?
Thank you for your advice.  Best regards,
Dehong
Re: streamdevice to find the last match Benjamin Franksen
Re: streamdevice to find the last match Dirk Zimoch
Prev: RE: CSS/BOY detached view position [SEC=UNCLASSIFIED] Chen, Xihui
Next: RE: EPICS and MEDM with eclipse Brown, Garth
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: new version of caQtDM Mezger Anton Christian
Next: Re: streamdevice to find the last match Benjamin Franksen
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
