1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: query ioc/cas for list of channels
To: Jameson Graef Rollins <[email protected]>
Date: Thu, 22 Aug 2013 12:15:44 +0000
Hi Jamie,
Just to be clear, you never connect to a record through channel access. When you do not include a field name, it appends the ".VAL" field tot he request.  The Channel Access interface did not have a DBR type to support this data structure. It has been a problem with the flat name space from the start. People have used the dbl command to populate relational databases or other directory services with the earliest one I am aware of completed at Jefferson Lab. The strength of V3 was that it is robust, high performance, and has a narrow interface to all of those channels, allowing the development of general client applications that are common to SCADA systems. Version 4 continues this strategy, but expands the protocol with several new communication mechanisms and an expanded (but limited) set of Normative Types.
We now have a ChannelFinder service. This is supported over the EPICS V4 protocol or from its http: interface. It is populated by a small application that redirects a command local to the IOC boot ("dbl") and sends it to the ChannelFinder service. Once it is populated, the user can add tags, and properties to the record names. The properties can be used to add field names to the record name. So all interesting Channels can be referenced through the channel finder service. Requests can then be made that do not require any knowledge of the name of the records. Control System Studio has several widgets that are directly integrated with this service for creating plots or tables that are populated from the ChannelFinder Service.
Bob
From: [email protected] [[email protected]] on behalf of Jameson Graef Rollins [[email protected]]
Sent: Wednesday, August 21, 2013 1:42 PM
To: J. Lewis Muir
Cc: EPICS tech-talk
Subject: Re: query ioc/cas for list of channels
On Wed, Aug 21 2013, "J. Lewis Muir" <[email protected]> wrote:
> On 8/21/13 11:13 AM, Jameson Graef Rollins wrote:
>> Hi, folks.  Is there a way to query a channel access server (IOC,
>> portable CAS, etc.) for a list of all records it is serving?  I feel
>> like there should be a way, but I haven't been able to find any way to
>> do this yet.
> Hi, Jamie.
> Have you searched the mailing list archive?  I think the following
> thread would help you:
>   http://www.aps.anl.gov/epics/tech-talk/2012/msg02486.php
Hi, Lewis.  Thanks for the link.  I did a quick scan back through the
list, but it was clearly not sufficient!  This thread wasn't even from
that long ago :(
But it is indeed the same thing I was looking for.  And unfortunately it
sounds like there's good way to query a channel server for a list of its
records.
I must say I'm quite surprised to find out there's no method for doing
this.  It seems like a pretty obviously useful feature.
> Also note the difference between records and PVs.  Your subject field
> refers to channels (i.e. PVs), but your message body is asking for a
> list of records.  The two are different.  For each record, there are
> many possible PV names corresponding to the fields of the record.
Yes, sorry, that was maybe a little sloppy.  But I would settle for
either, actually, since there's obviously a lot of overlap.  The set of
records is just a subset of the set of PVs, and the additional fields in
the full set of PVs is predictable from the set of records.
jamie.
query ioc/cas for list of channels Jameson Graef Rollins
Re: query ioc/cas for list of channels J. Lewis Muir
Re: query ioc/cas for list of channels Jameson Graef Rollins
Prev: Re: EPICS and MEDM with eclipse Pete Jemian
Next: Re: EPICS and MEDM with eclipse Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: query ioc/cas for list of channels Zelazny, Michael Stanley
Next: autosave per-db req files Stubbs, Scott A.
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
