The ASYN serial port code issues reads and writes at the lowest level so that should work. The trick is to get all the termios stuff out of the way, which isn't that easy since the termios VMIN/VTIM stuff is used for handling read timeouts. Do you know if the '/dev/usbtmcxxxx' devices support poll()?
we were able to improve the situation a little bit. It looks like the native usbtmc support is broken since kernel 2.6.28-11. We installed the driver from Agilent on our Debian 3.2.46-1 x86_64 machine and now we have /dev/usbtmc0 which returns information about the connected devices and /dev/usbtmc1 ... usbtmc16. With the latter we can now repeatedly communicate using echo (for example 'echo *IDN?>/dev/usbtmc1') and cat with the device and we get meaningful results. However, using the serial driver from asyn does not work, I guess since it is not a pure serial device but rather a normal file in the linux file system where you can write to and read from.
Is there any possibility to get this working with asyn or do we have to find a new solution?
Cheers,
Flo
- Re: Thorlabs USB Hardare with EPICS Sorgenfrei, Florian
autosave per-db req files Stubbs, Scott A.
RE: Thorlabs USB Hardare with EPICS Mark Rivers
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
