Please send the entire output when your IOC starts up, including the asyn commands to create the serial port driver and configure the baud rate, etc.
I've been trying to connect to my machine by RS232.
I use streamDevice and Asyn Module.
When we send command "*IDN?", we expect to get "THERMO OK" from the machine.
I try the same connection on TCP/IP. I used serial to ethernet converter and communicated with the machine. No problem occured. But when I eliminated the converter and directly connected to the PC on RS232 port, I got the following error
when I send the command.
I guess the problem is about response time. How can I configure the response time? Or if it is not response time problem, how can I fix it?
"2013/08/19 16:23:15.340949 thermoConn IDN: No reply from device within 1000 ms"
- Response Time Yasemin Barutçu
asynPortDriver question Jörn Wüstenfeld
Modbus write register update when locally modified haquin
<2013>
Re: Response Time Pearson, Matthew R.
RE: Response Time Emmanuel Mayssat
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
