1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: putNotify db links
To: Dirk Zimoch <[email protected]>
Cc: EPICS <[email protected]>
Date: Thu, 15 Aug 2013 11:12:39 -0500
Hi Dirk,
On 08/15/2013 10:18 AM, Dirk Zimoch wrote:
Is it possible to make a database link wait for completion?
Not a regular link, but the "Async Soft Channel" output device supports that come with Base 3.14 do exactly that. In 3.15 we also provide input device supports which do process-get as well, which Marty had to do some major internal surgery to support. The facility is now called process-notify instead of put-notify as a result.
Now it would be nice to have "put notify" links, e.g:
    field (LNK1, "A.PROC PN")
So that LNK2 is only processed when the whole LNK1 chain has finished
processing.
Unfortunately we can't do this for regular links because the API that record types call to do put and get operations on regular links doesn't provide for the necessary callback-on-completion which would allow for asynchronous operations like that. Making this something that could be configured on a per-link basis would require rewriting every record type to support such links.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
putNotify db links Dirk Zimoch
Prev: Re: putNotify db links Pearson, Matthew R.
Next: RE: High density thermal diode monitoring Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: DeltaTau Clipper, DeltaTau & EtherCAT, Beckhoff PV
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
