The sseq record supports put_notify:
http://www.aps.anl.gov/bcda/synApps/std/sseqRecord.html
I've used this in the past to replace seq record instances.
Cheers,
Matt
On Aug 15, 2013, at 11:18 AM, Dirk Zimoch <[email protected]> wrote:
> Hello all,
> Is it possible to make a database link wait for completion?
> If not, is this worth to be considered for a future EPICS version?
> Example:
> A seq record S triggers two records, A and B. A has an asynchronous
> device support (or is the beginning of a processing chain that contains
> an asynchronous device support).
> record (seq, "S")
> field (LNK1, "A.PROC PP")
> field (LNK2, "B.PROC PP")
> record (ai, "A")
> field (DTYP, "async dev sup")
> field (INP, "...")
> record (ao, "B")
> field (OMSL, "closed_loop")
> field (DOL, "A")
> field (OUT, "...")
> When I do a caput with callback to S, the call only returns after A and
> B have both processed, as expected.
> caput -w 10 -c S 1
> However, B starts processing before A has finished. That is because A is
> asynchronous. Thus A has only just started processing when B is
> triggered. This is bad if B (or something down its processing chain)
> depends on A because B gets an old value.
> Now it would be nice to have "put notify" links, e.g:
> field (LNK1, "A.PROC PN")
> So that LNK2 is only processed when the whole LNK1 chain has finished
> processing.
> The same syntax and mechanism may be useful for input links too in order
> to avoid getting old values from asynchronous device supports.
> Any comments?
> Does something like this already exists or is it already planned?
> I think with dbPutNotify the necessary infrastructure is already there.
> Dirk
- putNotify db links Dirk Zimoch
Re: putNotify db links Andrew Johnson
<2013>
<2013>
