Are you using RTEMS or some other operating system?
Looks like there's no easy mechanism in the EPICS RTEMS support for changing the speed from the BSP default that is set in c/src/lib/libbsp/m68k/uC5282/console/console.c
It might be possible use gdb to change the executable image -- the console speed value is stored at IntUartInfo+8, but that's certainly not very convenient.
On Aug 14, 2013, at 10:11 AM, Yoram Fisher <[email protected]> wrote:
> I am using MCF5282 and the default baud rate to the console is 9600 baud. I would like to change it to 115200. Any know how this can be done?
> Thanks
> - Yoram -
> Yoram Fisher
> Senior Systems Engineer
> Sydor Instruments, LLC
> 291 Millstead Way
> Rochester, New York 14624
> Ph: +1.585.278.1168, Fax: +1.585.278.1169
> Email: [email protected]
> web: www.sydorinstruments.com
Eric Norum
[email protected]
- Setting console buad rate Yoram Fisher
Re: AW: [asyn] link already open! Andrew Johnson
High density thermal diode monitoring Arnold, Ned D.
<2013>
Persistent storage on Arcturus uC5282 Yoram Fisher
<2013>
