1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Should Linux C++ builds have debug symbols by default in R3.14.12.3?
To: <[email protected]>
Date: Wed, 14 Aug 2013 10:40:09 +0000
Hi all,
We're starting to move IOCs from R3.14.11 to R3.14.12.3 and I've noticed that C++ builds with host arch linux-x86_64 no longer have debugging symbols by default, but C builds do. In R3.14.11 we used to have debugging symbols on C and C++ builds even when NOT using the linux-x86_64-debug architecture.
The change seems to be that in R3.14.11/base/configure/os/CONFIG_SITE.Common.linux-x86_64 we have:
OP_SYS_CFLAGS += -g
But in R3.14.12.3/base/configure/os/CONFIG_SITE.Common.linux-x86_64 we have:
OPT_CFLAGS_YES += -g
My guess is that the change was probably made for a good reason, so we should add the following line to configure/os/CONFIG_SITE.Common.linux-x86_64:
OPT_CXXFLAGS_YES += -g
Is that the correct way to fix this?
Tom Cobb
Re: Should Linux C++ builds have debug symbols by default in R3.14.12.3? Andrew Johnson
Prev: Re: Accessing Raspberry Pi GPIO through EPICS Peter Milne
Next: Re: AW: [asyn] link already open! Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Accessing Raspberry Pi GPIO through EPICS Peter Linardakis
Next: Re: Should Linux C++ builds have debug symbols by default in R3.14.12.3? Andrew Johnson
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
