1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [asyn] link already open!
To: Pavel Maslov <[email protected]>
Date: Mon, 12 Aug 2013 14:55:43 +0200
On 12.08.2013 14:08, Pavel Maslov wrote:
I think I have understood the origin of these messages. A possible
remedy is not to include base.dbd in the "main" IOC, because it has
already been included in the support module's dbd file.
Thanks to all who helped!
When I build loadable modules, I use base.dbd only in the main IOC, but not in the module. My module .dbd contains only what is defined inside the module itself.
Dirk
Pavel Maslov, MS
On Mon, Aug 12, 2013 at 9:48 AM, Pavel Maslov <[email protected]
<mailto:[email protected]>> wrote:
    Hi Dirk,
    Thanks for a good pointer - my asyn and streamdevice versions didn't
    match! Now everything works.
    I get a couple of warnings, though. Do you know what they say?
    registryFunctionRefAdd: could not register asSubInit
    Warning -- iocshRegisterVariable redefining asCaDebug.
    Warning -- iocshRegisterVariable redefining dbRecordsOnceOnly.
    Warning -- iocshRegisterVariable redefining dbBptNotMonotonic.
    Pavel Maslov, MS
    On Mon, Aug 12, 2013 at 9:06 AM, Dirk Zimoch <[email protected]
        On 09.08.2013 17:05, Pavel Maslov wrote:
            Mark, I cannot do anything to StreamDevice records - I mean
            I can caget
            and caput, but everytime they get processed - those error
            messages pop
            up. And the PVs are invalid all the time never change
            values. This said,
            I can talk to my Java Simulator using asynrecord:
            dbpf lambda1-ps:asyn.AOUT "*idn?"
            , and I get the response. No problem. So it's StreamDevice
            that produces
            these errors (as you pointed out). Also, I don't think that
            my Java
            Simulator is slow. I tried your solution to lengthen the
            auto connect
            time but the problem still remains.
            What I am confident in, though, (sorry for not telling this
            before) is
            that it has to do with the fact that I am loading
            asyn+streamdevice
            support module dynamically (from iocsh).
            When I use it the normal EPICS way - everything is fine as
            it should be.
        I do the same and that works for me. But you have to be careful:
        Are you sure that you load the same version of asyn that you
        used to compile StreamDevice?
        Sometimes the binary API of asyn changes from one version to
        another (although the source API is the same). That happens when
        functions pointers in the function tables get re-ordered in a
        new asyn version.
        Dirk
            Pavel Maslov, MS
            On Fri, Aug 9, 2013 at 4:14 PM, Mark Rivers
            <[email protected] <mailto:[email protected]>
            <mailto:[email protected].__edu
            <mailto:[email protected]>>> wrote:
                 You have created the port with autoconnect disabled.
              Thus, I expect
                 the error message that says that queueRequest failed,
            because the
                 port is not connected.  But then asynReport says that
            the port is
                 connected.  This must be because StreamDevice connected
            it?  But
                 once it is connected then your StreamDevice records
            should work
                 correctly.  Do they?  If you force an input or output
            record to
                 process does it work?
                 One possibility for your problem is that your Java
            server takes
                 longer than 0.5 second to connect.   If a port has
            autoconnect
                 enabled, then when the port is first connected asyn
            will try to
                 connect to it, but it will only wait 0.5 seconds by
            default.  You
                 can lengthen that time to 2 seconds, for example with
            this command
                 before you create the IP port.
                 asynSetAutoConnectTimeout 2.0
                 You can also try to wait for the port to connect in
            your startup
                 script with this command:
                 asynWaitConnect(const char *portName, double timeout)
                 i.e.
                 asynWaitConnect("lambda1", 2.0)
                 right after your drvAsynIPPortConfigure command.
                 __________________________________
            <mailto:pavel.masloff@gmail.__com
            <mailto:[email protected]>>]
                 Sent: Friday, August 09, 2013 9:00 AM
                 To: Mark Rivers; EPICS Tech Talk
                 Hi Mark!
                 The error occurs at iocInit (since my PVs have
            PINI=YES) and each
                 time I read/write via CA.
                 The server is a Java Device Simulator at
            localhost:7001. It is
                 always running and it never disconnects. All of my PVs
            are marked
                 Invalid. In fact they have not been initialized.
                 I have tried with noAutoConnect=1 and this is what i get:
                 epics> 2013/08/09 15:48:06.034504 CAS-client
                 lambda-ps:PWR_OUTPUT:RBV lockRequest:
            pasynManager->queueRequest()
                 failed: port lambda1 not connected
                 epics> asynReport 2
                 lambda1 multiDevice:No canBlock:Yes autoConnect:No
                      enabled:Yes connected:Yes numberConnects 1
                      nDevices 0 nQueued 0 blocked:No
                      asynManagerLock:No synchronousLock:No
                      exceptionActive:No exceptionUsers 2 exceptionNotifys 0
                      interposeInterfaceList
                          asynOctet pinterface 0x7fdceea29800 drvPvt
            0x1c6f820
                      interfaceList
                          asynCommon pinterface 0x7fdceea26c60 drvPvt
            0x1c6c270
                          asynOctet pinterface 0x1c6c2f8 drvPvt 0x1c6c270
                      Port 127.0.0.1:7001 <http://127.0.0.1:7001>
            <http://127.0.0.1:7001><http:/__/127.0.0.1:7001
            <http://127.0.0.1:7001>>: Connected
                                      fd: 9
                      Characters written: 0
                         Characters read: 0
                 Pavel Maslov, MS
                 On Fri, Aug 9, 2013 at 3:16 PM, Mark Rivers
            <mailto:[email protected]>><mailto:rivers@cars.__uchicago.edu
            <mailto:[email protected]>>>> wrote:
                 Please provide some more information:
                 - When does the error occur?  At iocInit when
            connecting to the
                 device for the first time?  When the server first comes
            on line?
                   When the server is restarted?
                 - The server is at port 7001 on the localhost.  Is that
            server
                 always running when the IOC is running?  Does the
            server disconnect
                 after each transaction?
                 You have created the drvAsynIPPort with the default
            value of 0 for
                 the last 3 parameters, so it is using noAutoConnect=0,
            which means
                 that asynManager will automatically try to connect the
            port before
                 queuing a request.  If the connection attempt fails
            then asynManager
                 will not queue the request.  So I am having a hard time
                 understanding how StreamDevice found the port
            disconnected, unless
                 your server disconnected in the time between when
            asynManager queued
                 the request and when StreamDevice was called.
            <mailto:tech-talk-bounces@aps.__anl.gov
            <mailto:[email protected]>><mailto:[email protected]
                 [[email protected]
            <mailto:[email protected]>>>] on behalf of Pavel
            Maslov
                 [[email protected] <mailto:[email protected]>
            <mailto:[email protected]>><mailto:pavel.masloff@__gmail.com
                 Sent: Friday, August 09, 2013 4:20 AM
                 To: EPICS Tech Talk
                 Subject: [asyn] link already open!
                 Hello all,
                 When can this message pop up:
                 2013/08/09 11:03:11.051131 lambda1 lambda-ps:CURR:MAX:RBV:
                 pasynCommon->connect() failed: 127.0.0.1:7001
            <http://127.0.0.1:7001>><http://127.0.__0.1:7001
                 Link already open!
                 2013/08/09 11:03:11.052968 lambda1
            lambda-ps:CURR:MAX:RBV: Protocol
                 aborted
                 Pavel Maslov, MS
                 Controls Engineer
Re: [asyn] link already open! Pavel Maslov
RE: [asyn] link already open! Mark Rivers
Re: [asyn] link already open! Dirk Zimoch
Prev: Re: [asyn] link already open! Pavel Maslov
Next: Re: [asyn] link already open! Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
