1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: motor record & PC6K: HOMF/HOMR broken
To: [email protected]
Date: Fri, 09 Aug 2013 16:37:11 -0400
Hello,
here is my next problem regarding the Parker motor controllers: When I trigger HOMF/HOMR the motor record sends "1HOM0"/"1HOM1" followed by "GO" to the device. Unfortunately my Gemini GT6K controller starts going to the home position immediately after it receives the "HOM" command and aborts the homing procedure when it receives the "GO" command :-(
The relevant line seems to be motorRecord.cc:1940 (R6-8). Commenting out this line fixes the problem for me. But obviously this is not really a solution since it almost certainly breaks the behavior of other motor controllers :-(
Do I have to consider this feature broken for the PC6Ks? Did anyone run into the same problem with other types of PC6K controllers or do the HOMF/HOMR fields work for other models?
Best regards,
Martin
Prev: RE: Modbus Mark Rivers
Next: EtherCAT [SEC=UNOFFICIAL] LYNCH, Damien
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: AW: [asyn] link already open! Dirk Zimoch
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
