1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: motorRecord simulation & STUP field
To: "Konrad, Martin" <[email protected]>
Date: Fri, 9 Aug 2013 12:38:28 -0400
There's clearly a difference here. You get:
epics> dbpf mkp:Mot:Sim1.STUP 1
2013/08/09 11:34:35.688 mkp:Mot:Sim1 devMotorAsyn::update_values, needUpdate=0
2013/08/09 11:34:35.688 devMotorAsyn::send_msg: mkp:Mot:Sim1 command=10, pact=1
2013/08/09 11:34:35.688 sim1 addr 1 queueRequest priority 0 not lockHolder
2013/08/09 11:34:35.688 asynManager::portThread port=sim1 callback
DBR_STRING:          "BUSY"
2013/08/09 11:34:35.688 devMotorAsyn::asynCallback: mkp:Mot:Sim1 command=18, ivalue=0, dvalue=0.000000
2013/08/09 11:34:35.688 drvMotorAsyn::writeInt32, reason=109, value=0
but I get:
2013/08/09 09:23:50.305 mkp:Mot:Sim1 devMotorAsyn::update_values, needUpdate=0
2013/08/09 09:23:50.305 devMotorAsyn::send_msg: mkp:Mot:Sim1 command=10, pact=1
2013/08/09 09:23:50.305 sim1 addr 1 queueRequest priority 0 not lockHolder
DBR_STRING:          "BUSY"
epics> 2013/08/09 09:23:50.305 asynManager::portThread port=sim1 callback
2013/08/09 09:23:50.305 devMotorAsyn::asynCallback: mkp:Mot:Sim1 command=18, ivalue=0, dvalue=0.000000, pasynUser->reason=109
2013/08/09 09:23:50.305 mkp:Mot:Sim1 devMotorAsyn::statusCallback new value=[p:0.000000,e:0.000000,s:a]
2013/08/09 09:23:50.305 mkp:Mot:Sim1 devMotorAsyn::update_values, needUpdate=1
2013/08/09 09:23:50.306 drvMotorAsyn::writeInt32, reason=109, value=0
The reason that STUP is not being set back is because the record isn't being processed due to a callback from the driver (the statusCallback function).
Also, I'm not sure we're using the same version of the motor record. The devMotorAsyn::asynCallback print statement is different. The pasynUser->reason=109 is missing from yours. This reason field is actually the one used to trigger the status update in the driver.
I took a look at motor 6-7-1… are you sure you're not using that version, even when you tested R6-8? In the sim driver I see this added recently:
* 2012-10-09 rls - Added motorAxisforceCallback to support motor record
 *                GET_INFO commands.
which might explain it….
Cheers,
Matt
On Aug 9, 2013, at 11:37 AM, "Konrad, Martin" <[email protected]> wrote:
>> I'm also using R6-8 here.
>> If you send me a tar file of your IOC, I'll build it here and see if I can reproduce it.
>> Maybe a detailed Asyn trace would also help.
> See attachment. Let me know if you need further details.
> Martin
> <testSimSupport.tar.bz2><ioc_shell_with_debugging_output.txt>
motorRecord simulation & STUP field Konrad, Martin
Re: motorRecord simulation & STUP field Ron Sluiter
Re: motorRecord simulation & STUP field Konrad, Martin
Prev: Re: motorRecord simulation & STUP field Ron Sluiter
Next: Re: motorRecord simulation & STUP field Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: motorRecord simulation & STUP field Konrad, Martin
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
