Hi Ron,
> Looking at the differences between the github and SVN versions of
> the motor module, I see lots of lines with,
> < send_mess(card, buff, (char) NULL);
> > send_mess(card, buff, (char *) NULL);
> We are not getting warnings on these lines and we should. What
> platform and compiler are you using where you see these warnings?
Probably I'm using a more recent compiler: gcc 4.7.3 as well as clang
3.2, both on Ubuntu 13.04.
By the way: There are some more warnings (see attachment). For some of
them I don't feel comfortable in fixing them since my understanding of
the motor record code is still limited.
Martin
make -C ./configure install
make[1]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/configure'
perl /usr/lib/epics/bin/linux-x86_64-debug/makeMakefile.pl O.linux-x86_64-debug ../..
mkdir O.Common
make -C O.linux-x86_64-debug -f ../Makefile TOP=../.. T_A=linux-x86_64-debug install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/configure/O.linux-x86_64-debug'
perl /usr/lib/epics/bin/linux-x86_64-debug/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/configure/O.linux-x86_64-debug'
make[1]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/configure'
make -C ./motorApp install
make[1]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp'
make -C ./MotorSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSrc'
perl /usr/lib/epics/bin/linux-x86_64-debug/makeMakefile.pl O.linux-x86_64-debug ../../..
mkdir O.Common
make -C O.linux-x86_64-debug -f ../Makefile TOP=../../.. T_A=linux-x86_64-debug install
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/motorSupport.dbd
mkdir ../../../dbd
Installing dbd file ../../../dbd/motorRecord.dbd
echo "../O.Common/motorRecord.h : ../Makefile" >> motorRecord.h.d
/usr/lib/epics/bin/linux-x86_64-debug/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd -I/usr/lib/epics/dbd -I/usr/lib/epics/dbd ../motorRecord.dbd motorRecord.h
Installing generic include file ../../../include/motor.h
mkdir ../../../include
Installing generic include file ../../../include/motordevCom.h
Installing generic include file ../../../include/motordrvCom.h
Installing generic include file ../../../include/motordrvComCode.h
Installing generic include file ../../../include/motor_interface.h
Installing generic include file ../../../include/paramLib.h
Installing generic include file ../../../include/asynMotorController.h
Installing generic include file ../../../include/asynMotorAxis.h
Installing generated generic include file ../../../include/motorRecord.h
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../motorRecord.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../motordevCom.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../motordrvCom.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../motorUtil.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../motorUtilAux.cc
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMotorAsyn.c
../drvMotorAsyn.c:470:50: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
(*pPvt->drvset->getInteger)(pAxis->axis, command, value);
../drvMotorAsyn.c:459:14: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
case -1: /* This is commands we know about but don't want int32 interface for */
../drvMotorAsyn.c:508:54: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
(*pPvt->drvset->getInteger)(pAxis->axis, command, (epicsInt32*)value);
../drvMotorAsyn.c:502:14: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
case -1: /* This is commands we know about but don't want uint32digital interface for */
../drvMotorAsyn.c:560:50: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
(*pPvt->drvset->getDouble)(pAxis->axis, command, value);
../drvMotorAsyn.c:543:15: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
case -1:
../drvMotorAsyn.c:625:59: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
status = (*pPvt->drvset->setInteger)(pAxis->axis, command, value);
../drvMotorAsyn.c:603:14: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
case -1:
../drvMotorAsyn.c:665:54: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
(*pPvt->drvset->getInteger)(pAxis->axis, command, (epicsInt32*)&temp);
../drvMotorAsyn.c:668:63: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
status = (*pPvt->drvset->setInteger)(pAxis->axis, command, temp);
../drvMotorAsyn.c:659:14: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
case -1:
../drvMotorAsyn.c:748:58: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
status = (*pPvt->drvset->setDouble)(pAxis->axis, command, value);
../drvMotorAsyn.c:705:14: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
case -1:
../drvMotorAsyn.c:781:49: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
(*pPvt->drvset->getDouble)(pAxis->axis, motorPosition,
../drvMotorAsyn.c:783:49: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
(*pPvt->drvset->getDouble)(pAxis->axis, motorEncoderPosition,
../drvMotorAsyn.c:785:49: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
(*pPvt->drvset->getDouble)(pAxis->axis, motorVelocity,
16 warnings generated.
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devMotorAsyn.c
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../paramLib.c
../paramLib.c:110:15: warning: comparison of unsigned expression >= 0 is always true [-Wtautological-compare]
if (index >= 0 && index < params->nvals)
../paramLib.c:139:15: warning: comparison of unsigned expression >= 0 is always true [-Wtautological-compare]
if (index >=0 && index < params->nvals)
../paramLib.c:168:15: warning: comparison of unsigned expression >= 0 is always true [-Wtautological-compare]
../paramLib.c:197:15: warning: comparison of unsigned expression >= 0 is always true [-Wtautological-compare]
4 warnings generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../asynMotorController.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../asynMotorAxis.cpp
/usr/bin/ar -rc libmotor.a motorRecord.o motordevCom.o motordrvCom.o motorUtil.o motorUtilAux.o drvMotorAsyn.o devMotorAsyn.o paramLib.o asynMotorController.o asynMotorAxis.o
/usr/bin/ranlib libmotor.a
/usr/bin/clang++ -o libmotor.so -shared -fPIC -Wl,-soname,libmotor.so -Wl,-hlibmotor.so -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 motorRecord.o motordevCom.o motordrvCom.o motorUtil.o motorUtilAux.o drvMotorAsyn.o devMotorAsyn.o paramLib.o asynMotorController.o asynMotorAxis.o -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libmotor.so
mkdir ../../../lib
mkdir ../../../lib/linux-x86_64-debug
Installing library ../../../lib/linux-x86_64-debug/libmotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSrc'
make -C ./DeltaTauSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/DeltaTauSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/DeltaTauSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devDeltaTau.dbd
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/DeltaTauSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/DeltaTauSrc'
make -C ./OmsSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devOms.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devOmsPC68.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvOmsPC68.cc
../drvOmsPC68.cc:111:28: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *oms_axis[] = {"X", "Y", "Z", "T", "U", "V", "R", "S"};
../drvOmsPC68.cc:111:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:38: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:43: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:48: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:53: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:58: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:63: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:691:9: warning: add explicit braces to avoid dangling else [-Wdangling-else]
else
9 warnings generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devOms.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvOms.cc
../drvOms.cc:156:28: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:38: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:43: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:48: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:53: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:58: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:63: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:996:19: warning: variable 'status' is uninitialized when used here [-Wuninitialized]
errPrintf(status, __FILE__, __LINE__, "Can't disconnect vector %d\n",
../drvOms.cc:980:16: note: initialize the variable 'status' to silence this warning
long status;
= 0
../drvOms.cc:1157:54: warning: variable 'localaddr' is uninitialized when used here [-Wuninitialized]
Debug(9, "motor_init: localaddr = %p\n", localaddr);
../drvOms.cc:1096:29: note: initialize the variable 'localaddr' to silence this warning
volatile void *localaddr;
= NULL
../drvOms.cc:827:13: warning: unused function 'motorIsr' [-Wunused-function]
static void motorIsr(int card)
../drvOms.cc:975:13: warning: unused function 'motorIsrDisable' [-Wunused-function]
static void motorIsrDisable(int card)
12 warnings generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devOms58.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvOms58.cc
../drvOms58.cc:183:30: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *oms58_axis[] = {"X", "Y", "Z", "T", "U", "V", "R", "S"};
../drvOms58.cc:183:35: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:45: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:50: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:55: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:60: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:65: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:1166:54: warning: variable 'localaddr' is uninitialized when used here [-Wuninitialized]
../drvOms58.cc:1108:29: note: initialize the variable 'localaddr' to silence this warning
= NULL
../drvOms58.cc:1152:27: warning: variable 'status' is uninitialized when used here [-Wuninitialized]
if (PROBE_SUCCESS(status))
../drvOms58.cc:143:33: note: expanded from macro 'PROBE_SUCCESS'
#define PROBE_SUCCESS(STATUS) ((STATUS)==S_dev_addressOverlap)
../drvOms58.cc:1103:16: note: initialize the variable 'status' to silence this warning
long status;
= 0
../drvOms58.cc:983:13: warning: unused function 'motorIsr' [-Wunused-function]
11 warnings generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devMAXv.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMAXv.cc
../drvMAXv.cc:170:29: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *MAXv_axis[] = {"X", "Y", "Z", "T", "U", "V", "R", "S"};
../drvMAXv.cc:170:34: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:39: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:44: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:49: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:54: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:59: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:64: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:917:30: warning: cast to 'char *' from smaller integer type 'unsigned int' [-Wint-to-pointer-cast]
MAXv_addrs = (char *) addrs;
../drvMAXv.cc:930:30: warning: cast to 'char *' from smaller integer type 'unsigned int' [-Wint-to-pointer-cast]
../drvMAXv.cc:943:30: warning: cast to 'char *' from smaller integer type 'unsigned int' [-Wint-to-pointer-cast]
../drvMAXv.cc:1040:13: warning: unused function 'motorIsr' [-Wunused-function]
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devOmsCom.cc
/usr/bin/ar -rc liboms.a devOmsPC68.o drvOmsPC68.o devOms.o drvOms.o devOms58.o drvOms58.o devMAXv.o drvMAXv.o devOmsCom.o
/usr/bin/ranlib liboms.a
/usr/bin/clang++ -o liboms.so -shared -fPIC -Wl,-soname,liboms.so -Wl,-hliboms.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 devOmsPC68.o drvOmsPC68.o devOms.o drvOms.o devOms58.o drvOms58.o devMAXv.o drvMAXv.o devOmsCom.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/liboms.so
Installing library ../../../lib/linux-x86_64-debug/liboms.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsSrc'
make -C ./SoftMotorSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SoftMotorSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SoftMotorSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devSoftMotor.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devSoft.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devSoftAux.cc
/usr/bin/ar -rc libsoftMotor.a devSoft.o devSoftAux.o
/usr/bin/ranlib libsoftMotor.a
/usr/bin/clang++ -o libsoftMotor.so -shared -fPIC -Wl,-soname,libsoftMotor.so -Wl,-hlibsoftMotor.so -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 devSoft.o devSoftAux.o -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libsoftMotor.so
Installing library ../../../lib/linux-x86_64-debug/libsoftMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SoftMotorSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SoftMotorSrc'
make -C ./OmsAsynSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsAsynSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsAsynSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/omsAsynSupport.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../omsBaseAxis.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../omsBaseController.cpp
../omsBaseController.cpp:231:24: warning: unused variable 'functionName' [-Wunused-variable]
static const char *functionName = "readInt32";
1 warning generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../omsMAXnet.cpp
In file included from ../omsMAXnet.cpp:19:
../omsMAXnet.h:38:11: warning: private field 'serialPortName' is not used [-Wunused-private-field]
char* serialPortName;
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../omsMAXv.cpp
../omsMAXv.cpp:98:17: warning: comparison of unsigned expression < 0 is always false [-Wtautological-compare]
if (vmeAddr < 0) {
../omsMAXv.cpp:172:21: warning: cast to 'void *' from smaller integer type 'unsigned int' [-Wint-to-pointer-cast]
probeAddr = (void*) vmeAddr;
../omsMAXv.cpp:362:24: warning: unused variable 'functionName' [-Wunused-variable]
static const char* functionName = "sendReceive";
../omsMAXv.cpp:501:28: warning: cast to 'char *' from smaller integer type 'unsigned int' [-Wint-to-pointer-cast]
omsMAXv::baseAddress = (char *) addrs;
In file included from ../omsMAXv.cpp:24:
../omsMAXv.h:173:10: warning: private field 'readBuffer' is not used [-Wunused-private-field]
char readBuffer[BUFFER_SIZE];
5 warnings generated.
/usr/bin/ar -rc libomsAsyn.a omsBaseAxis.o omsBaseController.o omsMAXnet.o omsMAXv.o
/usr/bin/ranlib libomsAsyn.a
/usr/bin/clang++ -o libomsAsyn.so -shared -fPIC -Wl,-soname,libomsAsyn.so -Wl,-hlibomsAsyn.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 omsBaseAxis.o omsBaseController.o omsMAXnet.o omsMAXv.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libomsAsyn.so
Installing library ../../../lib/linux-x86_64-debug/libomsAsyn.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsAsynSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsAsynSrc'
make -C ./MotorSimSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSimSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSimSrc/O.linux-x86_64-debug'
perl /usr/lib/epics/bin/linux-x86_64-debug/makeIncludeDbd.pl base.dbd asyn.dbd motorSupport.dbd motorSimSupport.dbd motorSimInclude.dbd
echo "../O.Common/motorSimInclude.dbd : ../Makefile" >> motorSim.dbd.d
Expanding dbd
Installing dbd file ../../../dbd/motorSimSupport.dbd
Installing created dbd file ../../../dbd/motorSim.dbd
Installing db file ../../../db/motorSimTest.db
mkdir ../../../db
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../route.c
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devMotorSim.c
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMotorSim.c
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../motorSimDriver.cpp
In file included from ../motorSimDriver.cpp:25:
../motorSimDriver.h:51:18: warning: private field 'tLast_' is not used [-Wunused-private-field]
epicsTimeStamp tLast_;
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../motorSimRegister.cc
/usr/bin/ar -rc libmotorSimSupport.a route.o devMotorSim.o drvMotorSim.o motorSimDriver.o motorSimRegister.o
/usr/bin/ranlib libmotorSimSupport.a
/usr/bin/clang++ -o libmotorSimSupport.so -shared -fPIC -Wl,-soname,libmotorSimSupport.so -Wl,-hlibmotorSimSupport.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 route.o devMotorSim.o drvMotorSim.o motorSimDriver.o motorSimRegister.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libmotorSimSupport.so
Installing library ../../../lib/linux-x86_64-debug/libmotorSimSupport.a
perl /usr/lib/epics/bin/linux-x86_64-debug/registerRecordDeviceDriver.pl ../O.Common/motorSim.dbd motorSim_registerRecordDeviceDriver /home/marko/work/stripperFoilPlatter/motorTest/motorR6-8 > motorSim.tmp
mv motorSim.tmp motorSim_registerRecordDeviceDriver.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include motorSim_registerRecordDeviceDriver.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../motorSimMain.cpp
/usr/bin/clang++ -o motorSim -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 motorSim_registerRecordDeviceDriver.o motorSimMain.o -lmotorSimSupport -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
Installing created file ../../../bin/linux-x86_64-debug/motorSim
mkdir ../../../bin
mkdir ../../../bin/linux-x86_64-debug
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSimSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSimSrc'
make -C ./NewportSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewportSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewportSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devNewport.dbd
Installing generic include file ../../../include/XPS_C8_drivers.h
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../NewportRegister.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devMM3000.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMM3000.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devMM4000.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMM4000.cc
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMM4000Asyn.c
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPM500.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPM500.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devESP300.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvESP300.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../SMC100Driver.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../AG_UC.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../AG_CONEX.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../asynOctetSocket.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../XPS_C8_drivers.cpp
../XPS_C8_drivers.cpp:4605:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
if (pt != NULL) sscanf (pt, "%d", &boolScanTmp);
../XPS_C8_drivers.cpp:4606:30: note: uninitialized use occurs here
*ClosedLoopStatus = (bool) boolScanTmp;
../XPS_C8_drivers.cpp:4605:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:4584:17: note: initialize the variable 'boolScanTmp' to silence this warning
int boolScanTmp;
= 0
../XPS_C8_drivers.cpp:4739:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:4740:30: note: uninitialized use occurs here
../XPS_C8_drivers.cpp:4739:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:4718:17: note: initialize the variable 'boolScanTmp' to silence this warning
int boolScanTmp;
= 0
../XPS_C8_drivers.cpp:4877:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:4878:30: note: uninitialized use occurs here
../XPS_C8_drivers.cpp:4877:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:4856:17: note: initialize the variable 'boolScanTmp' to silence this warning
int boolScanTmp;
= 0
../XPS_C8_drivers.cpp:5001:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:5002:30: note: uninitialized use occurs here
../XPS_C8_drivers.cpp:5001:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:4980:17: note: initialize the variable 'boolScanTmp' to silence this warning
int boolScanTmp;
= 0
../XPS_C8_drivers.cpp:6153:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:6154:25: note: uninitialized use occurs here
*EnableState = (bool) boolScanTmp;
../XPS_C8_drivers.cpp:6153:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:6126:17: note: initialize the variable 'boolScanTmp' to silence this warning
int boolScanTmp;
= 0
../XPS_C8_drivers.cpp:6245:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:6246:25: note: uninitialized use occurs here
../XPS_C8_drivers.cpp:6245:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:6215:17: note: initialize the variable 'boolScanTmp' to silence this warning
int boolScanTmp;
= 0
../XPS_C8_drivers.cpp:6839:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:6840:25: note: uninitialized use occurs here
../XPS_C8_drivers.cpp:6839:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:6809:17: note: initialize the variable 'boolScanTmp' to silence this warning
int boolScanTmp;
= 0
7 warnings generated.
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvXPSAsynAux.c
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../xps_ftp.c
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvXPSAsyn.c
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../XPSAsynInterpose.c
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../XPSController.cpp
In file included from ../XPSController.cpp:93:
../XPSController.h:44:14: warning: 'XPSController::initializeProfile' hides overloaded virtual function [-Woverloaded-virtual]
asynStatus initializeProfile(size_t maxPoints, const char* ftpUsername, const char* ftpPassword);
../../../include/asynMotorController.h:171:22: note: hidden overloaded virtual function 'asynMotorController::initializeProfile' declared here
virtual asynStatus initializeProfile(size_t maxPoints);
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../XPSAxis.cpp
In file included from ../XPSAxis.cpp:97:
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../hxp_drivers.cpp
../hxp_drivers.cpp:55:4: warning: expression result unused [-Wunused-value]
*pt++;
../hxp_drivers.cpp:3644:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../hxp_drivers.cpp:3645:30: note: uninitialized use occurs here
../hxp_drivers.cpp:3644:3: note: remove the 'if' if its condition is always true
../hxp_drivers.cpp:3623:17: note: initialize the variable 'boolScanTmp' to silence this warning
int boolScanTmp;
= 0
../hxp_drivers.cpp:3778:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../hxp_drivers.cpp:3779:30: note: uninitialized use occurs here
../hxp_drivers.cpp:3778:3: note: remove the 'if' if its condition is always true
../hxp_drivers.cpp:3757:17: note: initialize the variable 'boolScanTmp' to silence this warning
int boolScanTmp;
= 0
../hxp_drivers.cpp:3916:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../hxp_drivers.cpp:3917:30: note: uninitialized use occurs here
../hxp_drivers.cpp:3916:3: note: remove the 'if' if its condition is always true
../hxp_drivers.cpp:3895:17: note: initialize the variable 'boolScanTmp' to silence this warning
int boolScanTmp;
= 0
../hxp_drivers.cpp:4040:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../hxp_drivers.cpp:4041:30: note: uninitialized use occurs here
../hxp_drivers.cpp:4040:3: note: remove the 'if' if its condition is always true
../hxp_drivers.cpp:4019:17: note: initialize the variable 'boolScanTmp' to silence this warning
int boolScanTmp;
= 0
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../HXPDriver.cpp
In file included from ../HXPDriver.cpp:21:
../HXPDriver.h:79:10: warning: private field 'mres_' is not used [-Wunused-private-field]
double mres_;
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../XPSGathering.c
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../XPSGatheringRegister.c
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../tclCall.cc
/usr/bin/ar -rc libNewport.a NewportRegister.o devMM3000.o drvMM3000.o devMM4000.o drvMM4000.o drvMM4000Asyn.o devPM500.o drvPM500.o devESP300.o drvESP300.o SMC100Driver.o AG_UC.o AG_CONEX.o asynOctetSocket.o XPS_C8_drivers.o drvXPSAsynAux.o xps_ftp.o drvXPSAsyn.o XPSAsynInterpose.o XPSController.o XPSAxis.o hxp_drivers.o HXPDriver.o XPSGathering.o XPSGatheringRegister.o tclCall.o
/usr/bin/ranlib libNewport.a
/usr/bin/clang++ -o libNewport.so -shared -fPIC -Wl,-soname,libNewport.so -Wl,-hlibNewport.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 NewportRegister.o devMM3000.o drvMM3000.o devMM4000.o drvMM4000.o drvMM4000Asyn.o devPM500.o drvPM500.o devESP300.o drvESP300.o SMC100Driver.o AG_UC.o AG_CONEX.o asynOctetSocket.o XPS_C8_drivers.o drvXPSAsynAux.o xps_ftp.o drvXPSAsyn.o XPSAsynInterpose.o XPSController.o XPSAxis.o hxp_drivers.o HXPDriver.o XPSGathering.o XPSGatheringRegister.o tclCall.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libNewport.so
Installing library ../../../lib/linux-x86_64-debug/libNewport.a
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../XPSGatheringMain.c
/usr/bin/clang++ -o XPSGatheringMain -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 XPSGatheringMain.o -lNewport -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../XPSGathering2.c
/usr/bin/clang++ -o XPSGathering2 -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 XPSGathering2.o -lNewport -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
Installing created file ../../../bin/linux-x86_64-debug/XPSGatheringMain
Installing created file ../../../bin/linux-x86_64-debug/XPSGathering2
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewportSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewportSrc'
make -C ./ImsSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ImsSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ImsSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devImsMotor.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../ImsRegister.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devIM483SM.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvIM483SM.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devIM483PL.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvIM483PL.cc
../drvIM483PL.cc:95:32: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *IM483PL_axis[] = {"A", "B", "C", "D", "E", "F", "G", "H"};
../drvIM483PL.cc:95:37: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:42: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:47: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:52: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:57: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:62: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:67: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
8 warnings generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devMDrive.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMDrive.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../ImsMDrivePlusMotorController.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../ImsMDrivePlusMotorAxis.cpp
../ImsMDrivePlusMotorAxis.cpp:307:13: warning: using the result of an assignment as a condition without parentheses [-Wparentheses]
if (status = setAxisMoveParameters(minVelocity, maxVelocity, acceleration)) goto bail;
../ImsMDrivePlusMotorAxis.cpp:307:13: note: place parentheses around the assignment to silence this warning
../ImsMDrivePlusMotorAxis.cpp:307:13: note: use '==' to turn this assignment into an equality comparison
/usr/bin/ar -rc libIms.a ImsRegister.o devIM483SM.o drvIM483SM.o devIM483PL.o drvIM483PL.o devMDrive.o drvMDrive.o ImsMDrivePlusMotorController.o ImsMDrivePlusMotorAxis.o
/usr/bin/ranlib libIms.a
/usr/bin/clang++ -o libIms.so -shared -fPIC -Wl,-soname,libIms.so -Wl,-hlibIms.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 ImsRegister.o devIM483SM.o drvIM483SM.o devIM483PL.o drvIM483PL.o devMDrive.o drvMDrive.o ImsMDrivePlusMotorController.o ImsMDrivePlusMotorAxis.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libIms.so
Installing library ../../../lib/linux-x86_64-debug/libIms.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ImsSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ImsSrc'
make -C ./AcsSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devAcsMotor.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../AcsRegister.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devMCB4B.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMCB4B.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../MCB4BDriver.cpp
/usr/bin/ar -rc libAcs.a AcsRegister.o devMCB4B.o drvMCB4B.o MCB4BDriver.o
/usr/bin/ranlib libAcs.a
/usr/bin/clang++ -o libAcs.so -shared -fPIC -Wl,-soname,libAcs.so -Wl,-hlibAcs.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 AcsRegister.o devMCB4B.o drvMCB4B.o MCB4BDriver.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libAcs.so
Installing library ../../../lib/linux-x86_64-debug/libAcs.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsSrc'
make -C ./MclennanSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MclennanSrc'
perl /usr/lib/epics/bin/linux-x86_64-debug/makeMakefile.pl O.linux-x86_64-debug ../../..
mkdir O.Common
make -C O.linux-x86_64-debug -f ../Makefile TOP=../../.. T_A=linux-x86_64-debug install
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MclennanSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devMclennanMotor.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../MclennanRegister.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPM304.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPM304.cc
/usr/bin/ar -rc libMclennan.a MclennanRegister.o devPM304.o drvPM304.o
/usr/bin/ranlib libMclennan.a
/usr/bin/clang++ -o libMclennan.so -shared -fPIC -Wl,-soname,libMclennan.so -Wl,-hlibMclennan.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 MclennanRegister.o devPM304.o drvPM304.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libMclennan.so
Installing library ../../../lib/linux-x86_64-debug/libMclennan.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MclennanSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MclennanSrc'
make -C ./PiSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devPIMotor.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPIC844.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPIC844.cc
../drvPIC844.cc:90:32: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIC844_axis[4] = {"1", "2", "3", "4"};
../drvPIC844.cc:90:37: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC844.cc:90:42: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC844.cc:90:47: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PiRegister.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPIC630.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPIC630.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIC630Register.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPIC848.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPIC848.cc
../drvPIC848.cc:80:32: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIC848_axis[4] = {"A", "B", "C", "D"};
../drvPIC848.cc:80:37: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC848.cc:80:42: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC848.cc:80:47: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
4 warnings generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIC848Register.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPIC662.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPIC662.cc
../drvPIC662.cc:82:32: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIC662_axis[4] = {"1", "2", "3", "4"};
../drvPIC662.cc:82:37: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC662.cc:82:42: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC662.cc:82:47: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIC662Register.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPIC862.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPIC862.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIC862Register.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPIC663.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPIC663.cc
../drvPIC663.cc:200:55: warning: unused variable 'LSactiveH' [-Wunused-variable]
bool plusdir, ls_active = false, plusLS, minusLS, LSactiveH;
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIC663Register.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPIE710.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPIE710.cc
../drvPIE710.cc:78:31: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIE710_axis[] = {"1", "2", "3", "4", "5", "6"};
../drvPIE710.cc:78:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE710.cc:78:41: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE710.cc:78:46: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE710.cc:78:51: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE710.cc:78:56: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
6 warnings generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIE710Register.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPIE516.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPIE516.cc
../drvPIE516.cc:86:31: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIE516_axis[] = {"A", "B", "C"};
../drvPIE516.cc:86:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE516.cc:86:41: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
3 warnings generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIE516Register.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPIE816.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPIE816.cc
../drvPIE816.cc:91:31: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIE816_axis[] = {"A", "B", "C", "D", "E", "F", "G", "H", "I", "J",
../drvPIE816.cc:91:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:41: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:46: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:51: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:56: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:61: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:66: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:71: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:76: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:92:32: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
"K","L"};
../drvPIE816.cc:92:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
"K","L"};
../drvPIE816.cc:235:66: warning: unused variable 'online_status' [-Wunused-variable]
unsigned int overflow_status, ontarget_status, servo_status, online_status;
../drvPIE816.cc:580:10: warning: unused variable 'retry' [-Wunused-variable]
int retry = 0;
14 warnings generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIE816Register.cc
/usr/bin/ar -rc libPI.a devPIC844.o drvPIC844.o PiRegister.o devPIC630.o drvPIC630.o PIC630Register.o devPIC848.o drvPIC848.o PIC848Register.o devPIC662.o drvPIC662.o PIC662Register.o devPIC862.o drvPIC862.o PIC862Register.o devPIC663.o drvPIC663.o PIC663Register.o devPIE710.o drvPIE710.o PIE710Register.o devPIE516.o drvPIE516.o PIE516Register.o devPIE816.o drvPIE816.o PIE816Register.o
/usr/bin/ranlib libPI.a
/usr/bin/clang++ -o libPI.so -shared -fPIC -Wl,-soname,libPI.so -Wl,-hlibPI.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 devPIC844.o drvPIC844.o PiRegister.o devPIC630.o drvPIC630.o PIC630Register.o devPIC848.o drvPIC848.o PIC848Register.o devPIC662.o drvPIC662.o PIC662Register.o devPIC862.o drvPIC862.o PIC862Register.o devPIC663.o drvPIC663.o PIC663Register.o devPIE710.o drvPIE710.o PIE710Register.o devPIE516.o drvPIE516.o PIE516Register.o devPIE816.o drvPIE816.o PIE816Register.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libPI.so
Installing library ../../../lib/linux-x86_64-debug/libPI.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiSrc'
make -C ./PIGCS2Src install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PIGCS2Src'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PIGCS2Src/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/PI_GCS2Support.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIasynController.cpp
../PIasynController.cpp:63:4: warning: field 'm_pGCSController' will be initialized after field 'movesDeferred' [-Wreorder]
, m_pGCSController( NULL )
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIasynAxis.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIGCSController.cpp
../PIGCSController.cpp:317:13: warning: unused variable 'status' [-Wunused-variable]
asynStatus status;
../PIGCSController.cpp:318:7: warning: unused variable 'cmd' [-Wunused-variable]
char cmd[100];
2 warnings generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIGCSMotorController.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIGCSPiezoController.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIE517Controller.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIE755Controller.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIHexapodController.cpp
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIC702Controller.cpp
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../translateerror.c
/usr/bin/ar -rc libPI_GCS2Support.a PIasynController.o PIasynAxis.o PIGCSController.o PIGCSMotorController.o PIGCSPiezoController.o PIE517Controller.o PIE755Controller.o PIHexapodController.o PIC702Controller.o translateerror.o
/usr/bin/ranlib libPI_GCS2Support.a
/usr/bin/clang++ -o libPI_GCS2Support.so -shared -fPIC -Wl,-soname,libPI_GCS2Support.so -Wl,-hlibPI_GCS2Support.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 PIasynController.o PIasynAxis.o PIGCSController.o PIGCSMotorController.o PIGCSPiezoController.o PIE517Controller.o PIE755Controller.o PIHexapodController.o PIC702Controller.o translateerror.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libPI_GCS2Support.so
Installing library ../../../lib/linux-x86_64-debug/libPI_GCS2Support.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PIGCS2Src/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PIGCS2Src'
make -C ./MicroMoSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicroMoSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicroMoSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devMicroMo.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../MicroMoRegister.cc
../MicroMoRegister.cc:54:13: warning: unused function 'configMicroMoCallFunc' [-Wunused-function]
static void configMicroMoCallFunc(const iocshArgBuf *args)
1 warning generated.
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devMVP2001.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMVP2001.cc
/usr/bin/ar -rc libMicroMo.a MicroMoRegister.o devMVP2001.o drvMVP2001.o
/usr/bin/ranlib libMicroMo.a
/usr/bin/clang++ -o libMicroMo.so -shared -fPIC -Wl,-soname,libMicroMo.so -Wl,-hlibMicroMo.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 MicroMoRegister.o devMVP2001.o drvMVP2001.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libMicroMo.so
Installing library ../../../lib/linux-x86_64-debug/libMicroMo.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicroMoSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicroMoSrc'
make -C ./MicosSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicosSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicosSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devMicos.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../MicosRegister.cc
../MicosRegister.cc:54:13: warning: unused function 'configMicosCallFunc' [-Wunused-function]
static void configMicosCallFunc(const iocshArgBuf *args)
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devMicos.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMicos.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../SMChydraDriver.cpp
In file included from ../SMChydraDriver.cpp:21:
../SMChydraDriver.h:38:10: warning: private field 'mres_' is not used [-Wunused-private-field]
double mres_;
/usr/bin/ar -rc libMicos.a MicosRegister.o devMicos.o drvMicos.o SMChydraDriver.o
/usr/bin/ranlib libMicos.a
/usr/bin/clang++ -o libMicos.so -shared -fPIC -Wl,-soname,libMicos.so -Wl,-hlibMicos.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 MicosRegister.o devMicos.o drvMicos.o SMChydraDriver.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libMicos.so
Installing library ../../../lib/linux-x86_64-debug/libMicos.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicosSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicosSrc'
make -C ./FaulhaberSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/FaulhaberSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/FaulhaberSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devFaulhaberMotor.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devMCDC2805.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMCDC2805.cc
../drvMCDC2805.cc:80:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *MCDC2805_axis[] = {"0", "1", "2", "3", "4", "5", "6", "7"};
../drvMCDC2805.cc:80:38: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:43: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:48: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:53: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:58: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:63: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:68: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
/usr/bin/ar -rc libFaulhaber.a devMCDC2805.o drvMCDC2805.o
/usr/bin/ranlib libFaulhaber.a
/usr/bin/clang++ -o libFaulhaber.so -shared -fPIC -Wl,-soname,libFaulhaber.so -Wl,-hlibFaulhaber.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 devMCDC2805.o drvMCDC2805.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libFaulhaber.so
Installing library ../../../lib/linux-x86_64-debug/libFaulhaber.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/FaulhaberSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/FaulhaberSrc'
make -C ./PC6KSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PC6KSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PC6KSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devPC6K.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../ParkerRegister.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPC6K.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPC6K.cc
/usr/bin/ar -rc libParker.a ParkerRegister.o devPC6K.o drvPC6K.o
/usr/bin/ranlib libParker.a
/usr/bin/clang++ -o libParker.so -shared -fPIC -Wl,-soname,libParker.so -Wl,-hlibParker.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 ParkerRegister.o devPC6K.o drvPC6K.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libParker.so
Installing library ../../../lib/linux-x86_64-debug/libParker.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PC6KSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PC6KSrc'
make -C ./NewFocusSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewFocusSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewFocusSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devNewFocus.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../NewFocusRegister.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPMNC87xx.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPMNC87xx.cc
/usr/bin/ar -rc libNewFocus.a NewFocusRegister.o devPMNC87xx.o drvPMNC87xx.o
/usr/bin/ranlib libNewFocus.a
/usr/bin/clang++ -o libNewFocus.so -shared -fPIC -Wl,-soname,libNewFocus.so -Wl,-hlibNewFocus.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 NewFocusRegister.o devPMNC87xx.o drvPMNC87xx.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libNewFocus.so
Installing library ../../../lib/linux-x86_64-debug/libNewFocus.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewFocusSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewFocusSrc'
make -C ./AcsTech80Src install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsTech80Src'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsTech80Src/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devSPiiPlus.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../ACSTech80Register.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devSPiiPlus.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvSPiiPlus.cc
../drvSPiiPlus.cc:91:30: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *ACSPL_axis[] = {"X", "Y", "Z", "T", "A", "B", "C", "D"};
../drvSPiiPlus.cc:91:35: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:45: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:50: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:55: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:60: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:65: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:97:4: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
{QSTATUS_CMND,QFAULT_CMND,QPOS_CMND,QEA_POS_CMND,QVEL_CMND,QHOME_CMND,QDONE_CMND},
../drvSPiiPlus.h:66:26: note: expanded from macro 'QSTATUS_CMND'
#define QSTATUS_CMND "?D/MST(%d)"
../drvSPiiPlus.cc:97:17: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:67:26: note: expanded from macro 'QFAULT_CMND'
#define QFAULT_CMND "?D/FAULT(%d)"
../drvSPiiPlus.cc:97:29: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:68:26: note: expanded from macro 'QPOS_CMND'
#define QPOS_CMND "?APOS(%d)"
../drvSPiiPlus.cc:97:39: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:69:26: note: expanded from macro 'QEA_POS_CMND'
#define QEA_POS_CMND "?FPOS(%d)"
../drvSPiiPlus.cc:97:52: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:71:26: note: expanded from macro 'QVEL_CMND'
#define QVEL_CMND "?FVEL(%d)"
../drvSPiiPlus.cc:97:62: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:72:26: note: expanded from macro 'QHOME_CMND'
#define QHOME_CMND "?opReq(%d)"
../drvSPiiPlus.cc:97:73: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:73:26: note: expanded from macro 'QDONE_CMND'
#define QDONE_CMND "?Done(%d)"
../drvSPiiPlus.cc:98:4: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
{QSTATUS_CMND,QFAULT_CMND,QPOS_CMND,QEA_POS_KIN_CMND,QVEL_CMND,SKIP_THIS,SKIP_THIS},
../drvSPiiPlus.cc:98:17: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:98:29: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:98:39: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:70:26: note: expanded from macro 'QEA_POS_KIN_CMND'
#define QEA_POS_KIN_CMND "?FPOS%s" // Read reverse kinimatic position ('CONNECT' mode)
../drvSPiiPlus.cc:98:56: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:98:66: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:65:25: note: expanded from macro 'SKIP_THIS'
#define SKIP_THIS "#"
../drvSPiiPlus.cc:98:76: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:4: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
{QSTATUS_CMND,QFAULT_CMND,QPOS_CMND,QEA_POS_CMND,QVEL_CMND,SKIP_THIS,SKIP_THIS}
../drvSPiiPlus.cc:99:17: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:29: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:39: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:52: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:62: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:72: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
29 warnings generated.
/usr/bin/ar -rc libacsTech80.a ACSTech80Register.o devSPiiPlus.o drvSPiiPlus.o
/usr/bin/ranlib libacsTech80.a
/usr/bin/clang++ -o libacsTech80.so -shared -fPIC -Wl,-soname,libacsTech80.so -Wl,-hlibacsTech80.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 ACSTech80Register.o devSPiiPlus.o drvSPiiPlus.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libacsTech80.so
Installing library ../../../lib/linux-x86_64-debug/libacsTech80.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsTech80Src/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsTech80Src'
make -C ./OrielSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OrielSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OrielSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devOriel.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -O0 -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../OrielRegister.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -O0 -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devEMC18011.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -O0 -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvEMC18011.cc
../drvEMC18011.cc:272:9: warning: variable 'brkptr' is uninitialized when used here [-Wuninitialized]
if (brkptr != endptr)
../drvEMC18011.cc:227:15: note: initialize the variable 'brkptr' to silence this warning
char *brkptr, *endptr;
= NULL
/usr/bin/ar -rc libOriel.a OrielRegister.o devEMC18011.o drvEMC18011.o
/usr/bin/ranlib libOriel.a
/usr/bin/clang++ -o libOriel.so -shared -fPIC -Wl,-soname,libOriel.so -Wl,-hlibOriel.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 OrielRegister.o devEMC18011.o drvEMC18011.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libOriel.so
Installing library ../../../lib/linux-x86_64-debug/libOriel.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OrielSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OrielSrc'
make -C ./ThorLabsSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ThorLabsSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ThorLabsSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devThorLabs.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -O0 -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../ThorLabsRegister.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -O0 -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devMDT695.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -O0 -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvMDT695.cc
../drvMDT695.cc:86:31: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *MDT694_axis[] = {"X", "Y", "Z"};
../drvMDT695.cc:86:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMDT695.cc:86:41: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
/usr/bin/ar -rc libThorLabs.a ThorLabsRegister.o devMDT695.o drvMDT695.o
/usr/bin/ranlib libThorLabs.a
/usr/bin/clang++ -o libThorLabs.so -shared -fPIC -Wl,-soname,libThorLabs.so -Wl,-hlibThorLabs.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 ThorLabsRegister.o devMDT695.o drvMDT695.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libThorLabs.so
Installing library ../../../lib/linux-x86_64-debug/libThorLabs.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ThorLabsSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ThorLabsSrc'
make -C ./SmartMotorSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmartMotorSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmartMotorSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devSmartMotorMotor.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devSmartMotor.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvSmartMotor.cc
../drvSmartMotor.cc:78:35: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *SmartMotor_addr[] = {"129", "130", "131", "132", "133", "134",
../drvSmartMotor.cc:78:42: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:78:49: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:78:56: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:78:63: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:78:70: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:79:5: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
"135", "136", "137", "138", "139", "140",
../drvSmartMotor.cc:79:12: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:79:19: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:79:26: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:79:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:79:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:80:5: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
"141", "142", "143", "144", "145", "146",
../drvSmartMotor.cc:80:12: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:80:19: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:80:26: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:80:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:80:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:81:5: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
"147", "148", "149", "150", "151", "152",
../drvSmartMotor.cc:81:12: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:81:19: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:81:26: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:81:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:81:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:82:5: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
"153", "154", "155", "156", "157", "158",
../drvSmartMotor.cc:82:12: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:82:19: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:82:26: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:82:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:82:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:83:5: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
"159", "160"};
../drvSmartMotor.cc:83:12: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
"159", "160"};
../drvSmartMotor.cc:430:9: warning: variable 'addr' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
if (cntrl->num_motors != 1) /* Test for daisy chain; echo mode. */
../drvSmartMotor.cc:440:86: note: uninitialized use occurs here
Debug(2, "send_mess(): message = %s for card# %d, addr# %d\n", local_buff, card, addr);
../drvSmartMotor.cc:430:5: note: remove the 'if' if its condition is always true
../drvSmartMotor.cc:404:32: note: initialize the variable 'addr' to silence this warning
int comsize, namesize, addr;
= 0
33 warnings generated.
/usr/bin/ar -rc libSmartMotor.a devSmartMotor.o drvSmartMotor.o
/usr/bin/ranlib libSmartMotor.a
/usr/bin/clang++ -o libSmartMotor.so -shared -fPIC -Wl,-soname,libSmartMotor.so -Wl,-hlibSmartMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 devSmartMotor.o drvSmartMotor.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libSmartMotor.so
Installing library ../../../lib/linux-x86_64-debug/libSmartMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmartMotorSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmartMotorSrc'
make -C ./PiJenaSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiJenaSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiJenaSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devPIJena.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devPIJEDS.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvPIJEDS.cc
../drvPIJEDS.cc:76:31: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIJEDS_axis[] = {"0", "1", "2", "3", "4", "5"};
../drvPIJEDS.cc:76:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:76:41: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:76:46: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:76:51: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:76:56: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:88:29: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *EDS_CMNDS[] = {READ_POS, READ_STATUS, READ_SLEW};
../drvPIJEDS.cc:84:23: note: expanded from macro 'READ_POS'
#define READ_POS "mess,#" /* Read position command */
../drvPIJEDS.cc:88:39: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:85:23: note: expanded from macro 'READ_STATUS'
#define READ_STATUS "stat,#" /* Read Motor Status */
../drvPIJEDS.cc:88:52: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:86:23: note: expanded from macro 'READ_SLEW'
#define READ_SLEW "sr,#" /* Read Slew Velocity V/ms */
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -DDEBUG -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../PIJEDS_Register.cc
/usr/bin/ar -rc libPIJena.a devPIJEDS.o drvPIJEDS.o PIJEDS_Register.o
/usr/bin/ranlib libPIJena.a
/usr/bin/clang++ -o libPIJena.so -shared -fPIC -Wl,-soname,libPIJena.so -Wl,-hlibPIJena.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 devPIJEDS.o drvPIJEDS.o PIJEDS_Register.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libPIJena.so
Installing library ../../../lib/linux-x86_64-debug/libPIJena.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiJenaSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiJenaSrc'
make -C ./KohzuSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/KohzuSrc'
perl /usr/lib/epics/bin/linux-x86_64-debug/makeMakefile.pl O.linux-x86_64-debug ../../..
mkdir O.Common
make -C O.linux-x86_64-debug -f ../Makefile TOP=../../.. T_A=linux-x86_64-debug install
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/KohzuSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devKohzuMotor.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devSC800.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvSC800.cc
/usr/bin/ar -rc libKohzuMotor.a devSC800.o drvSC800.o
/usr/bin/ranlib libKohzuMotor.a
/usr/bin/clang++ -o libKohzuMotor.so -shared -fPIC -Wl,-soname,libKohzuMotor.so -Wl,-hlibKohzuMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 devSC800.o drvSC800.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libKohzuMotor.so
Installing library ../../../lib/linux-x86_64-debug/libKohzuMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/KohzuSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/KohzuSrc'
make -C ./AttocubeSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AttocubeSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AttocubeSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devAttocube.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvANC150Asyn.cc
../drvANC150Asyn.cc:502:12: warning: unused function 'motorAxisProfileMove' [-Wunused-function]
static int motorAxisProfileMove(AXIS_HDL pAxis, int npoints, double positions[],
../drvANC150Asyn.cc:508:12: warning: unused function 'motorAxisTriggerProfile' [-Wunused-function]
static int motorAxisTriggerProfile(AXIS_HDL pAxis)
/usr/bin/ar -rc libAttocube.a drvANC150Asyn.o
/usr/bin/ranlib libAttocube.a
/usr/bin/clang++ -o libAttocube.so -shared -fPIC -Wl,-soname,libAttocube.so -Wl,-hlibAttocube.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 drvANC150Asyn.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libAttocube.so
Installing library ../../../lib/linux-x86_64-debug/libAttocube.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AttocubeSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AttocubeSrc'
make -C ./AerotechSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AerotechSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AerotechSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devAerotech.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../AerotechRegister.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../devSoloist.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvSoloist.cc
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../drvEnsembleAsyn.cc
/usr/bin/clang -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../concatString.c
/usr/bin/ar -rc libAerotech.a AerotechRegister.o devSoloist.o drvSoloist.o drvEnsembleAsyn.o concatString.o
/usr/bin/ranlib libAerotech.a
/usr/bin/clang++ -o libAerotech.so -shared -fPIC -Wl,-soname,libAerotech.so -Wl,-hlibAerotech.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 AerotechRegister.o devSoloist.o drvSoloist.o drvEnsembleAsyn.o concatString.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libAerotech.so
Installing library ../../../lib/linux-x86_64-debug/libAerotech.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AerotechSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AerotechSrc'
make -C ./HytecSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/HytecSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/HytecSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/HytecMotorDriver.dbd
Installing generic include file ../../../include/HytecMotorDriver.h
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../HytecMotorDriver.cpp
../HytecMotorDriver.cpp:277:17: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
char* hytecstr=" (HyTec Electronics Ltd., Reading, UK)";
../HytecMotorDriver.cpp:314:22: warning: format string is not a string literal (potentially insecure) [-Wformat-security]
if (ishytec) printf(hytecstr);
../HytecMotorDriver.cpp:353:3: warning: format specifies type 'unsigned short' but the argument has type 'int' [-Wformat]
expmodel);
../HytecMotorDriver.cpp:525:41: warning: cast to 'HytecMotorController *' from smaller integer type 'int' [-Wint-to-pointer-cast]
HytecMotorController *pController = (HytecMotorController*) pDrv;
In file included from ../HytecMotorDriver.cpp:80:
../HytecMotorDriver.h:156:6: warning: private field 'absAskingPosition' is not used [-Wunused-private-field]
int absAskingPosition;
../HytecMotorDriver.h:212:15: warning: private field 'pasynUser' is not used [-Wunused-private-field]
asynUser *pasynUser;
../HytecMotorDriver.h:219:19: warning: private field 'motorThread' is not used [-Wunused-private-field]
epicsThreadId motorThread;
7 warnings generated.
/usr/bin/ar -rc libHytecMotor.a HytecMotorDriver.o
/usr/bin/ranlib libHytecMotor.a
/usr/bin/clang++ -o libHytecMotor.so -shared -fPIC -Wl,-soname,libHytecMotor.so -Wl,-hlibHytecMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 HytecMotorDriver.o -lmotor -lasyn -lIpac -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libHytecMotor.so
Installing library ../../../lib/linux-x86_64-debug/libHytecMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/HytecSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/HytecSrc'
make -C ./ACRSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ACRSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ACRSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/ACRMotorSupport.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../ACRMotorDriver.cpp
/usr/bin/ar -rc libACRMotor.a ACRMotorDriver.o
/usr/bin/ranlib libACRMotor.a
/usr/bin/clang++ -o libACRMotor.so -shared -fPIC -Wl,-soname,libACRMotor.so -Wl,-hlibACRMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 ACRMotorDriver.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libACRMotor.so
Installing library ../../../lib/linux-x86_64-debug/libACRMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ACRSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ACRSrc'
make -C ./SmarActMCSSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmarActMCSSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmarActMCSSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devSmarActMCSMotor.dbd
Installing generic include file ../../../include/smarActMCSMotorDriver.h
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../smarActMCSMotorDriver.cpp
/usr/bin/ar -rc libsmarActMCSMotor.a smarActMCSMotorDriver.o
/usr/bin/ranlib libsmarActMCSMotor.a
/usr/bin/clang++ -o libsmarActMCSMotor.so -shared -fPIC -Wl,-soname,libsmarActMCSMotor.so -Wl,-hlibsmarActMCSMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 smarActMCSMotorDriver.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libsmarActMCSMotor.so
Installing library ../../../lib/linux-x86_64-debug/libsmarActMCSMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmarActMCSSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmarActMCSSrc'
make -C ./NPointSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NPointSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NPointSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/NPointMotorSupport.dbd
/usr/bin/clang++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include ../C300MotorDriver.cpp
/usr/bin/ar -rc libNPointMotor.a C300MotorDriver.o
/usr/bin/ranlib libNPointMotor.a
/usr/bin/clang++ -o libNPointMotor.so -shared -fPIC -Wl,-soname,libNPointMotor.so -Wl,-hlibNPointMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug -m64 C300MotorDriver.o -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libNPointMotor.so
Installing library ../../../lib/linux-x86_64-debug/libNPointMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NPointSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NPointSrc'
make -C ./Db install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/Db'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/Db/O.linux-x86_64-debug'
Installing db file ../../../db/motor.db
Installing db file ../../../db/basic_motor.db
Installing db file ../../../db/basic_asyn_motor.db
Installing db file ../../../db/IMS_extra.db
Installing db file ../../../db/XPSAuxAi.db
Installing db file ../../../db/XPSAuxAo.db
Installing db file ../../../db/XPSAuxBi.db
Installing db file ../../../db/XPSAuxBo.db
Installing db file ../../../db/XPSAuxLi.db
Installing db file ../../../db/XPSAuxLo.db
Installing db file ../../../db/XPS_extra.db
Installing db file ../../../db/HXP_extra.db
Installing db file ../../../db/HXP_coords.db
Installing db file ../../../db/ACRAux.template
Installing db file ../../../db/ACRAuxRead.template
Installing db file ../../../db/ACRAuxLi.template
Installing db file ../../../db/ACRAuxBi.template
Installing db file ../../../db/ACRAuxBo.template
Installing db file ../../../db/ACRAuxBoRBV.template
Installing db file ../../../db/TransPos.db
Installing db file ../../../db/motorUtil.db
Installing db file ../../../db/asyn_motor.db
Installing db file ../../../db/profileMoveController.template
Installing db file ../../../db/profileMoveAxis.template
Installing db file ../../../db/profileMoveControllerXPS.template
Installing db file ../../../db/profileMoveAxisXPS.template
Installing db file ../../../db/PI_Support.db
Installing db file ../../../db/PI_SupportCtrl.db
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/Db/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/Db'
make[1]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp'
- motor record: continuously update limit switches Konrad, Martin
- Re: motor record: continuously update limit switches Konrad, Martin
- RE: motor record: continuously update limit switches Williams Jr., Ernest L.
Re: motorRecord simulation & STUP field Pearson, Matthew R.
Re: [asyn] link already open! Pavel Maslov
<2013>
New Detectors Integrated Ahed Aladwan
<2013>
