1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: motorRecord simulation & STUP field
To: "Konrad, Martin" <[email protected]>
Date: Thu, 8 Aug 2013 15:03:05 -0500
Which release of the motor module are you using?
Kevin
On 8/8/13 12:47 PM, Konrad, Martin wrote:
> Hi,
> I came across the following issue while using motor record with
> DTYP="asynMotor". If I request a status update by
> $ caput test.STUP 1
> the field seems to stay in state BUSY forever:
> $ camonitor motorSim:test0.STUP
> test.STUP            2013-08-08 13:31:58.426150 OFF
> test.STUP            2013-08-08 13:31:58.426150 ON
> test.STUP            2013-08-08 13:32:47.299463 BUSY
> I guess that's not the intended behavior. Here is my database file
> (pretty much the example):
> record(motor,"test")
>    field(DESC,"Motor Simulation test")
>    field(DTYP, "asynMotor")
>    field(VELO,"1")
>    field(VBAS,"0")
>    field(VMAX,"1")
>    field(HVEL,"1")
>    field(ACCL,"1")
>    field(BDST,"0.01")
>    field(BVEL,"0.1")
>    field(BACC,"0.1")
>    field(OUT,"@asyn(sim1,1)")
>    field(MRES,"0.001")
>    field(PREC,"5")
>    field(EGU,"mm")
>    field(DHLM,"30")
>    field(DLLM,"-30")
> In st.cmd I have:
> motorSimCreate( 0, 0, -22000, 42000, 10000, 1, 2 )
> drvAsynMotorConfigure("sim1", "motorSim", 0, 2)
> Is the STUP field supposed to work with this device support?
> Regards,
> Martin
motorRecord simulation & STUP field Konrad, Martin
Prev: Re: motorRecord simulation & STUP field Pearson, Matthew R.
Next: RE: motor record: continuously update limit switches Williams Jr., Ernest L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: motorRecord simulation & STUP field Konrad, Martin
Next: Re: motorRecord simulation & STUP field Konrad, Martin
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
