1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Multiple Instances of JCA on Same Computer?
Date: Thu, 8 Aug 2013 14:12:29 +0000
Hello,
I'm currently working on a simulator for power plant diagnostics at Argonne.
Due to how our existing code base is designed, one of the components in our project requires multiple instances of JCA that may or may not be running at the same time. Ideally we would only have a single instance of JCA in a singleton object, but we don't want to fundamentally change how our project is structured.
What would be the best way to do this? I assume there is a way to have each instance of JCA use a separate port so there are no conflicts. As it stands now we just keep getting the following error:
java.net.SocketException: Unrecognized Windows Sockets error: 0: Cannot bind
Any thoughts?
Tom Olson
Prev: Re: Wireshark CA plugin Eric Williams
Next: database breakpoint, dbb(), and large linksets John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: mca Canberra DSA-2000 HV support Mark Rivers
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
