1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Wireshark CA plugin
To: [email protected]
Date: Wed, 7 Aug 2013 13:33:21 -0700
I'm running Wireshark 1.6.7 on my capture machine, so the older plugin could be problematic.
I may try your Lua script.  Does it care which version of Lua it runs on?
I'm working on some tools for analyzing CA virtual circuits in Python using dpkt, but the Wireshark plugin could be good enough for a lot of things.
eric
On Wed, Aug 7, 2013 at 8:46 AM, Michael Davidsaver <[email protected]> wrote:
I've also had difficulty in getting the wireshark-ca plugin to work (I was never successful).  So instead I wrote a plugin using the new(ish) Lua script interface to wireshark.  I've used this plugin successfully with wireshark 1.2.11 and 1.8.2.
https://github.com/mdavidsaver/cashark
Hope this can be of use,
Michael
On 08/07/2013 05:04 AM, Miha Vitorovic wrote:
Hi Eric,
the KEK-improved version 1.0.2 (minor-modified version for Wireshark 1.4.6 or later) seems to be missing in action, but you can download a bit older version here http://users.cosylab.com/~mvitorovic/wireshark-ca-1.0.1.tar.gz (production version with Wireshark 0.99.8 or 0.99.7)
Hope this helps. If you make it work with the latest wireshark version, please post a link here...
Br, Miha
On 6.8.2013 19:21, Eric Williams wrote:
I'm trying to locate the plugin for Wireshark for analyzing CA traffic described in this paper:
http://accelconf.web.cern.ch/accelconf/pc08/papers/tup008.pdf
The link in the paper (http://www-linac.kek.jp/cont/epics/wireshark/) no longer works, my browser is unable to connect to www-linac.kek.jp.
eric
Re: Wireshark CA plugin Michael Davidsaver
Wireshark CA plugin Eric Williams
Re: Wireshark CA plugin Miha Vitorovic
Prev: Re: Wireshark CA plugin Michael Davidsaver
Next: Re: Wireshark CA plugin Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
