The timeout value gets passed from my writeIt and readIt routines in my modbusIbterpose.c to the underlying IP driver in the pasynUser structure via these 2 statements:
static asynStatus writeIt(void *ppvt, asynUser *pasynUser,
const char *data, size_t numchars,
size_t *nbytesTransfered)
pasynUser->timeout = pPvt->timeout;
and
static asynStatus readIt(void *ppvt, asynUser *pasynUser,
char *data, size_t maxchars, size_t *nbytesTransfered,
int *eomReason)
So pPvt->timeout gets copied to pasynUser->timeout, and the pasynUser is passed to the underlying IP driver as follows:
/* Set number read to 0 in case of errors */
*nbytesTransfered = 0;
switch(pPvt->linkType) {
case modbusLinkTCP:
nRead = maxchars + mbapSize + 1;
status = pPvt->pasynOctet->read(pPvt->octetPvt, pasynUser,
pPvt->buffer, nRead,
&nbytesActual, eomReason);
Maybe your driver is not doing that copy to the pasynUser structure?
Sent: Tuesday, August 06, 2013 12:05 AM
To: Mark Rivers
Cc: Williams Jr., Ernest L.; [email protected]
Subject: Re: Modbus
After the call to pPvt->pasynOctet->read in modbusInterpose:readIt the
values are:
pPvt->timeout=1.0,
status=1,
eomReason=0.
I have simplified considerably the drvModbusAsynConfigure routine in my
version of the modbus driver. It must be that I have removed some code
fragment that is needed so that the drvAsynIPPort driver gets the
timeout value. I have to confess that I tried a few times to understand
how information is passed from one component to another in the asyn
module and each time I walked away from the problem without getting to
the bottom of it.
I wonder if you could outline how the pPvt->timeout value gets passed on
to the IPPort driver. This might help me see what I am missing in my
simplified version.
In a nutshell, I kept only two routines from the drvModbusAsyn.c, the
configure and doModbusIO routines. I made only slight modifications to
doModbusIO routine. On the other hand I simplified the configure
routine quite a lot. I removed all device support from it and more.
Sorry for troubling you with this,
Zen
On 08/05/13 17:45, Mark Rivers wrote:
> The timeout used by the drvAsynIPPort driver is the one passed in pasynUser->timeout, which is taken from pPvt->timeout in modbusInterpose.c.
> The pasynOctet->read() routine is the readIt function in drvAsynIPPort.c.
> When readIt fails what is the return code, and what is eomReason?
> Mark
> From: Zenon Szalata [[email protected]]
> Sent: Monday, August 05, 2013 3:01 PM
> To: Mark Rivers
> Subject: Re: Modbus
> Hi Mark,
> I think that the timeout you refer to is controlled via the third
> argument to modbusInterposeConfig routine. This is set to 1000 for all
> Beckhoff IOCs.
> I have not used the asyn trace facility because there are large number
> of IOs happening in one second. I will try it.
> I verified using a print statement in the readIt routine in
> modbusInterpose.c that the pPvt->timeout is 1.0, so, if this is the real
> timeout, then it is not used in the IO request.
> Is there a timeout in the drvAsynIPPort driver?
> I am looking at modbusInterpose.c and I find it difficult to tell what
> timeout the read routine is using. Here is the line from modbusInterpose.c:
> pPvt->buffer, nRead, &nbytesActual, eomReason);
> I can't tell how the pasyOctet->read routine is coded; not sure where it
> is defined and what timeout is used in the routine which ultimately
> issues the modbus read request.
> Now, in my new code, I put print statements in the writeIt and readIt
> routines in the modbusInterpose.c file and I see that the readIt fails
> immediately after writeIt completes with no perceivable delay.
> So I am confused.
> In the case of the IOCs using your modbus support module, there could be
> some other effect causing the error.
> For better or worse in these IOCs, I am setting up the IOCs such that
> drvModbusAsynConfigure is called for each Beckhoff bus terminal type. I
> use 100 ms period for the poller loop in each. I think each thread
> loops asynchronously with respect other threads. Therefore it is
> conceivable that often a write is issued from one thread when the
> coupler is not ready as it is processing some IO from another thread. I
> did not test this to see if this is indeed happening.
> To avoid this I have created a separate modbus IO class object in my new
> code, which uses a message queue to coordinate orderly execution of IO
> requests, which is done in a poller loop in this class. Requests for IO
> from multiple threads are scheduled for execution via the message queue.
> Thanks Mark,
> Zen
> On 08/05/13 10:23, Mark Rivers wrote:
>> Hi Zen,
>> What timeout are you using for your TCP read? The read does not actually put anything on the Ethernet, it just waits for a message to arrive from the Beckoff. So if you use a timeout of 1 second or so then it should never time out, assuming the module really does answer within 20 ms or so.
>> You need to turn on asynTrace in the underlying drvAsynIPPort driver to see exactly the timing of what is being sent and received by that driver.
>> Mark
>> Sent: Monday, August 05, 2013 11:33 AM
>> To: Mark Rivers; Ernest Williams; [email protected]
>> Subject: Modbus
>> Hi Mark,
>> I am nearly done with my version of modbus TCP for use with Beckhoff
>> hardware. I have a few IOCs using this support module and all seems to
>> be working well in my test area.
>> I have deployed an IOC for a couple of stepper motors controlled by
>> Beckhoff devices in a production area and discovered that the IOC is
>> generating many errors.
>> The error is:
>> 2013/08/05 08:55:14.982 modbusAsyn::doModbusIO port BKH15 error
>> calling writeRead, error=sioc-esb-bkh15:502 timeout: Resource
>> temporarily unavailable, nwrite=6/6, nread=0
>> Now, modbusAsyn is the name I used for the file which has the two
>> routines I took from your file drvModbusAsyn. Looking at the log files
>> of the IOCs used in the same production area which control Beckhoff
>> devices and which are built with your modbus support module, I see that
>> the same errors are generated. Here is an example:
>> 2013/06/16 13:19:25.918 drvModbusAsyn::doModbusIO port BKH10_CPL_R0
>> error calling writeRead, error=sioc-esb-bkh10:502 timeout: Resource
>> People who use these IOCs ignored these errors because mostly they did
>> not matter.
>> In the case of the stepper motor controller IOC it does matter. First of
>> all I realized that the difference between my testing environment and
>> that of production is the computer speed and a different networking
>> environment. The production computer used for the Beckhoff IOCs is much
>> faster. So it seems that there is some timing issue at work here.
>> After putting print statements in various places, I see that the routine
>> writeIt in modbusInterpose.c file always succeeds but the routine readIt
>> in the same file fails from time to time. I reread the manual for the
>> Beckhoff BK9000 Ethernet coupler and came across a statement saying that
>> the coupler takes from 13 to 15 ms to process a modbus message. So it
>> seems that the read comes too soon after the write. In my version of
>> the modbus support module for Beckhoff, I have added a 20 ms delay after
>> the pasynOctet->write in modbusInterpose.c and this has mostly solved
>> the problem. I say mostly, because I still see this error message but
>> very infrequently.
>> I am writing all this because I don't understand why this error is
>> generated so I am not sure if the direction I took to fix the problem is
>> correct. I also think that your modbus support module may need to be
>> modified if it is to be used with Beckhoff devices.
>> I would like to hear what you think about this.
>> Thanks,
>> Zen
- Re: Modbus Zenon Szalata
- Modbus Zenon Szalata
- RE: Modbus Mark Rivers
RE: Record Parameters in Asyn Port Driver Igor H. Soares Nunes
<2013>
<2013>
