The timeout used by the drvAsynIPPort driver is the one passed in pasynUser->timeout, which is taken from pPvt->timeout in modbusInterpose.c.
The pasynOctet->read() routine is the readIt function in drvAsynIPPort.c.
When readIt fails what is the return code, and what is eomReason?
Sent: Monday, August 05, 2013 3:01 PM
To: Mark Rivers
Cc: Williams Jr., Ernest L.; [email protected]
Subject: Re: Modbus
Hi Mark,
I think that the timeout you refer to is controlled via the third
argument to modbusInterposeConfig routine. This is set to 1000 for all
Beckhoff IOCs.
I have not used the asyn trace facility because there are large number
of IOs happening in one second. I will try it.
I verified using a print statement in the readIt routine in
modbusInterpose.c that the pPvt->timeout is 1.0, so, if this is the real
timeout, then it is not used in the IO request.
Is there a timeout in the drvAsynIPPort driver?
I am looking at modbusInterpose.c and I find it difficult to tell what
timeout the read routine is using. Here is the line from modbusInterpose.c:
status = pPvt->pasynOctet->read(pPvt->octetPvt, pasynUser,
pPvt->buffer, nRead, &nbytesActual, eomReason);
I can't tell how the pasyOctet->read routine is coded; not sure where it
is defined and what timeout is used in the routine which ultimately
issues the modbus read request.
Now, in my new code, I put print statements in the writeIt and readIt
routines in the modbusInterpose.c file and I see that the readIt fails
immediately after writeIt completes with no perceivable delay.
So I am confused.
In the case of the IOCs using your modbus support module, there could be
some other effect causing the error.
For better or worse in these IOCs, I am setting up the IOCs such that
drvModbusAsynConfigure is called for each Beckhoff bus terminal type. I
use 100 ms period for the poller loop in each. I think each thread
loops asynchronously with respect other threads. Therefore it is
conceivable that often a write is issued from one thread when the
coupler is not ready as it is processing some IO from another thread. I
did not test this to see if this is indeed happening.
To avoid this I have created a separate modbus IO class object in my new
code, which uses a message queue to coordinate orderly execution of IO
requests, which is done in a poller loop in this class. Requests for IO
from multiple threads are scheduled for execution via the message queue.
Thanks Mark,
Zen
On 08/05/13 10:23, Mark Rivers wrote:
> Hi Zen,
> What timeout are you using for your TCP read? The read does not actually put anything on the Ethernet, it just waits for a message to arrive from the Beckoff. So if you use a timeout of 1 second or so then it should never time out, assuming the module really does answer within 20 ms or so.
> You need to turn on asynTrace in the underlying drvAsynIPPort driver to see exactly the timing of what is being sent and received by that driver.
> Mark
> From: Zenon Szalata [[email protected]]
> Sent: Monday, August 05, 2013 11:33 AM
> To: Mark Rivers; Ernest Williams; [email protected]
> Subject: Modbus
> Hi Mark,
> I am nearly done with my version of modbus TCP for use with Beckhoff
> hardware. I have a few IOCs using this support module and all seems to
> be working well in my test area.
> I have deployed an IOC for a couple of stepper motors controlled by
> Beckhoff devices in a production area and discovered that the IOC is
> generating many errors.
> The error is:
> 2013/08/05 08:55:14.982 modbusAsyn::doModbusIO port BKH15 error
> calling writeRead, error=sioc-esb-bkh15:502 timeout: Resource
> temporarily unavailable, nwrite=6/6, nread=0
> Now, modbusAsyn is the name I used for the file which has the two
> routines I took from your file drvModbusAsyn. Looking at the log files
> of the IOCs used in the same production area which control Beckhoff
> devices and which are built with your modbus support module, I see that
> the same errors are generated. Here is an example:
> 2013/06/16 13:19:25.918 drvModbusAsyn::doModbusIO port BKH10_CPL_R0
> error calling writeRead, error=sioc-esb-bkh10:502 timeout: Resource
> People who use these IOCs ignored these errors because mostly they did
> not matter.
> In the case of the stepper motor controller IOC it does matter. First of
> all I realized that the difference between my testing environment and
> that of production is the computer speed and a different networking
> environment. The production computer used for the Beckhoff IOCs is much
> faster. So it seems that there is some timing issue at work here.
> After putting print statements in various places, I see that the routine
> writeIt in modbusInterpose.c file always succeeds but the routine readIt
> in the same file fails from time to time. I reread the manual for the
> Beckhoff BK9000 Ethernet coupler and came across a statement saying that
> the coupler takes from 13 to 15 ms to process a modbus message. So it
> seems that the read comes too soon after the write. In my version of
> the modbus support module for Beckhoff, I have added a 20 ms delay after
> the pasynOctet->write in modbusInterpose.c and this has mostly solved
> the problem. I say mostly, because I still see this error message but
> very infrequently.
> I am writing all this because I don't understand why this error is
> generated so I am not sure if the direction I took to fix the problem is
> correct. I also think that your modbus support module may need to be
> modified if it is to be used with Beckhoff devices.
> I would like to hear what you think about this.
> Thanks,
> Zen
- Re: Modbus Zenon Szalata
- Modbus Zenon Szalata
- RE: Modbus Mark Rivers
<2013>
<2013>
