Since you can communicate with the unit using simple shell commands I'm inferring that the unit presents itself as a USB-connected serial port. Standard StreamDevice + ASYN support should work fine.Dear all, I have some problems to establish a longer lasting connection with a Thorlabs PM100USB Powermeter. It is listed in /dev as usbtmc0 and I can communicate with it through echo –e. But this is only possible for one time. A second time echo –e won’t work. I have to disconnect and reconnect the USB-cable. Then again it will work one time. Could you help me with this problem? Note: This device has two chips, the first one is a XILINX XCR3064XL (AD Converter) and the second a NXP LPC2387FBD100. Best regards, Hardy Drube
- Re: Thorlabs USB Hardare with EPICS Jennings Guy
- Thorlabs USB Hardare with EPICS Drube, Hardy
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
