1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Power over ethernet
To: "Boyes, Matthew" <[email protected]>, "Hill, Bruce" <[email protected]>
Date: Wed, 31 Jul 2013 11:24:22 -0700
Got it, that device is actually to add PoE to a non PoE switch.
The link aggregation discussion I was looking at was for another product.
To: [email protected]; [email protected]
Date: Wed, 31 Jul 2013 11:11:26 -0700
CC: [email protected]
This switch supports PoE and PoE+... and is crazy cheap!
But the docs available before buying is almost non existent.
I use link aggregation/trunking for my network backbone and even so it says it is supported, I am wondering how many links can be aggregate and whether to expect compatibility issues with my other switches.
Moving forward with PoE, I found a company which offers Ultra and even Mega PoE.
I am not sure those are standard yet,  but up to 120W on CAT5 that's worth talking about!
So this morning, over coffee I shared the news about those PoE switches with the electronics guy.
To my surprise, one of them started drooling.
Granted, that was quite a sight, but I know what that meant: like me, he wanted one!
Date: Tue, 30 Jul 2013 17:43:01 -0700
Hello Emmanuel,
For LCLS-II electron controls we are moving to Gig-E cameras powered via PoE. We have successfully tested the following 24 port PoE injector with our new beamline camera system. It does support the IEEE 802.3at High Power PoE standard as well as the IEEE 802.3af standard.  We hope to deploy a system this summer into LCLS-I.
HPOE-2400G 24-Port 802.3at 30w Gigabit High Power over Ethernet Injector Hub
Hope that helps,
Matt
From: [email protected] [mailto:[email protected]] On Behalf Of Bruce Hill
Sent: Tuesday, July 30, 2013 4:53 PM
To: Emmanuel Mayssat
Cc: [email protected]
Subject: Re: Power over ethernet
Hi Emmanuel,
We've been using POE for webcam's and gigE cameras for
several years now and find it very useful, particularly
at our experimental chambers where we often need to move
cameras around.    Most of these devices are class 2, < 3.8W,
and we power them by adding POE modules to our Foundry
switches.   There's also available POE injectors which can be
added inline if your switch doesn't support POE.
We haven't used POE+, so I have no direct experience, but with
the small gauge of the wires in the ethernet cables you may
need to limit your cable lengths for higher power devices.
- Bruce
On 07/30/2013 04:07 PM, Emmanuel Mayssat wrote:
Hello,
After pushing for it, I was 'authorized' to investigate and test power over ethernet.
PoE is basically 48 V DC / 400 mA over CAT5/6, i.e. for <13Watt devices.
Is anyone of you using PoE? or PoE+ (<25W) ?
If so, any comment?
My long term goal is to have, with a minimum hassle,  embedded linux/EPICS in each of my chassis.
Emmanuel
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
RE: Power over ethernet nick.rees
Power over ethernet Emmanuel Mayssat
Re: Power over ethernet Bruce Hill
RE: Power over ethernet Boyes, Matthew
RE: Power over ethernet Emmanuel Mayssat
Prev: RE: Power over ethernet Emmanuel Mayssat
Next: RE: Power over ethernet nick.rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
