1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: vxWorks (tNetTask): arpresolve: lookup failed (resource shortage or network configuration error -- check netmask)
To: Brad Cumbia <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 30 Jul 2013 18:34:01 -0400
On Jul 30, 2013, at 5:45 PM, Brad Cumbia <[email protected]> wrote:
> Has anyone every experienced these errors before.
To ask the obvious . . .
Have you checked the netmask?
It looks like this is coming from the boot ROM startup and not your runtime kernel. There should not be much resource contention going on at that stage. Presuming you haven't recently modified your boot ROM, confirm the network configuration in the target's boot config. And confirm that you can arp resolve the IP address of the boot host from this host / network. A network sniffer like wireshark would be helpful to see what is happening to the arp requests.
Steven Hartman
[email protected]
vxWorks (tNetTask): arpresolve: lookup failed (resource shortage or network configuration error -- check netmask) Brad Cumbia
Prev: Re: asyn traceMask Brian McAllister
Next: Power over ethernet Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: vxWorks (tNetTask): arpresolve: lookup failed (resource shortage or network configuration error -- check netmask) Brad Cumbia
Next: RE: vxWorks (tNetTask): arpresolve: lookup failed (resource shortage or network configuration error -- check netmask) Hill, Jeff
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
