1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Problems with 64-bit EDM
To: <[email protected]>
Date: Mon, 29 Jul 2013 09:48:49 +0000
I have now attached the patch containing the changes which prevented the segfaults.
Will
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: 29 July 2013 09:27
To: [email protected]
Subject: FW: Problems with 64-bit EDM
Hello all,
I am new to EPICS and EDM, so please bear with me.
We have compiled EDM using a 64-bit compiler, and we find some segfaults: apparently only when we close a window containing an xyGraph.  We've tracked the cause down to xygraph.cc where there are various casts to longs (for example):
          case ProcessVariable::specificType::integer:
            if (  xyo->ySigned[i] ) {
              dyValue = (double) ( (long *) xyo->yPvData[i] )[n];
            else {
Since (apparently) EPICS integers are actually 32 bits, is this correct?  In practice, if I change all the casts to ints, I get no more segfaults.  I find that these casts were actually changed from ints in 1-12-41, with the comment 'fix for 64 bit systems, thanks to Sebastian Marsching'.
Can anyone shed any light on this?
Will Rogers
51c51
<     ( (long *) dest )[i] = (long) src;
>     ( (int *) dest )[i] = (int) src;
310c310
<               dyValue = (double) ( (long *) xyo->yPvData[i] )[n];
>               dyValue = (double) ( (int *) xyo->yPvData[i] )[n];
313c313
>               dyValue = (double) ( (unsigned int *) xyo->yPvData[i] )[n];
404c404
407c407
481c481
<               dxValue = (double) ( (long *) xyo->xPvData[i] )[n];
>               dxValue = (double) ( (int *) xyo->xPvData[i] )[n];
484c484
>               dxValue = (double) ( (unsigned int *) xyo->xPvData[i] )[n];
526c526
529c529
599c599
602c602
644c644
647c647
1025c1025
<             dxValue = (double) ( (long *) xyo->xPvData[i] )[ii];
>             dxValue = (double) ( (int *) xyo->xPvData[i] )[ii];
1028c1028
>             dxValue = (double) ( (unsigned int *) xyo->xPvData[i] )[ii];
1171c1171
1174c1174
1439c1439
<               dy1Value = (double) ( (long *) xyo->yPvData[i] )[ii];
>               dy1Value = (double) ( (int *) xyo->yPvData[i] )[ii];
1442c1442
>               dy1Value = (double) ( (unsigned int *) xyo->yPvData[i] )[ii];
1609c1609
1612c1612
1835c1835
<               dyValue = (double) ( (long *) xyo->yPvData[i] )[ii];
>               dyValue = (double) ( (int *) xyo->yPvData[i] )[ii];
1838c1838
>               dyValue = (double) ( (unsigned int *) xyo->yPvData[i] )[ii];
1914c1914
1917c1917
2220c2220
<               ( (long *) xyo->xPvData[i] )[ii] = pv->get_int();
>               ( (int *) xyo->xPvData[i] )[ii] = pv->get_int();
2223,2224c2223,2224
<               ( (unsigned long *) xyo->xPvData[i] )[ii] =
<                (unsigned long) pv->get_int();
>               ( (unsigned int *) xyo->xPvData[i] )[ii] =
>                (unsigned int) pv->get_int();
2282c2282
<               ( (long *) xyo->xPvData[i] )[ii] = pv->get_int_array()[ii];
>               ( (int *) xyo->xPvData[i] )[ii] = pv->get_int_array()[ii];
2285,2286c2285,2286
<                (unsigned long) pv->get_int_array()[ii];
>                (unsigned int) pv->get_int_array()[ii];
2369c2369
2372,2373c2372,2373
2437c2437
2440c2440
2518c2518
2521c2521
2777c2777
<               ( (long *) xyo->yPvData[i] )[ii] = pv->get_int();
>               ( (int *) xyo->yPvData[i] )[ii] = pv->get_int();
2780,2781c2780,2781
<               ( (unsigned long *) xyo->yPvData[i] )[ii] =
>               ( (unsigned int *) xyo->yPvData[i] )[ii] =
2839c2839
<               ( (long *) xyo->yPvData[i] )[ii] = pv->get_int_array()[ii];
>               ( (int *) xyo->yPvData[i] )[ii] = pv->get_int_array()[ii];
2842,2843c2842,2843
2926c2926
2929,2930c2929,2930
2994c2994
2997c2997
3075c3075
3078c3078
3250c3250
3253,3254c3253,3254
3312c3312
3315,3316c3315,3316
3409c3409
3413,3415c3413,3415
< 	  dyValue = (unsigned long) pv->get_int();
> 	  dyValue = (unsigned int) pv->get_int();
4383c4383
<               dxValue = (double) ( (long *) xPvData[i] )[ii];
>               dxValue = (double) ( (int *) xPvData[i] )[ii];
4386c4386
>               dxValue = (double) ( (unsigned int *) xPvData[i] )[ii];
4480c4480
<             dyValue[yi] = (double) ( (long *) yPvData[i] )[ii];
>             dyValue[yi] = (double) ( (int *) yPvData[i] )[ii];
4483c4483
>             dyValue[yi] = (double) ( (unsigned int *) yPvData[i] )[ii];
6120c6120
<             dyValue = (double) ( (long *) yPvData[i] )[ii];
>             dyValue = (double) ( (int *) yPvData[i] )[ii];
6123c6123
>             dyValue = (double) ( (unsigned int *) yPvData[i] )[ii];
6187c6187
6190c6190
6290c6290
6293c6293
6351c6351
6354c6354
6573c6573
6576c6576
6639c6639
6642c6642
9821c9821
9824c9824
9888c9888
9891c9891
FW: Problems with 64-bit EDM will.rogers
Prev: FW: Problems with 64-bit EDM will.rogers
Next: Electronic Logbooks Miroslav Pavleski
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
