1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Odd problems with RHEL6 diskless machines
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 24 Jul 2013 18:24:55 +0200
On 24.07.2013 17:33, Andrew Johnson wrote:
> Does this have anything to do with devIocStats [...] the old VxStats
> module on vxWorks has a lowest-priority idle thread [...].
> Take a look at the internals of devIocStats, and if it has such an
> idle task try disabling it (it should be asking the OS instead of
> trying to measure it anyway).
vxWorks is the *only* system where devIocStats uses this idle-thread
method. On all other systems, it uses the OS supplied mechanism to find
the CPU usage.
~Ralph
Odd problems with RHEL6 diskless machines tom.cobb
Re: Odd problems with RHEL6 diskless machines Andrew Johnson
Prev: RE: Odd problems with RHEL6 diskless machines tom.cobb
Next: RE: fsmRecord Initial State Costello, Charles C.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: motor record: continuously update limit switches Konrad, Martin
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
