On 07/13/2013 01:06 AM, Jiro Fujita
wrote:
...what is the minimum version of EPICS Base should
we be using?
I developed fsmRecord against 3.14.10 and it should build against
newer versions. Also, it isn't doing anything special, the only
part of OSI it uses is epicsMutex, so it will likely build against
earlier 3.14 releases.
This is something we probably should have thought
about before we started, but for a number of reasons, we
didn't.
And I didn't think to ask...
The subdetector system in question is mostly running EPICS base
3.13 or 3.12 (yes, we still have them around). For a number of
technical reasons it is not all that easy for us to recompile
EPICS base 3.12 IOCs (although not impossible, I suppose).
I wouldn't dream of discourage you from upgrading :) However, I
suspect it would be less work to port fsmRecord back. If you were
considering this you might have a look at StreamDevice which
supports 3.13 (specifically the file StreamEpics.cc). It might be
as simple as replacing use of epicsMutex with a vxWorks semaphore.
My thought is we can always edit the database of those IOCs to
add flnk to send the PV values to another PVs running on soft
IOC somewhere to get the job done (not very elegant, but should
work).
This is possible, but some care is needed. fsmRecord uses the
normal db linking calls, so puts to output CA links queue a request
and return immediately. So the FSM might have to include extra
states to check (and wait) until this has happened.
Michael
- Re: EPICS fsmRecord question Jiro Fujita
- EPICS fsmRecord question Jiro Fujita
Re: StreamDevice send/recevie bit array problem Dirk Zimoch
Re: Looking for STRUCK SIS3302 device driver Michael Davidsaver
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
