Measurement Computing makes USB relay boxes.
http://www.mccdaq.com/usb-data-acquisition/USB-ERB08-Series.aspx
You can wire your lights through these relays and control them from EPICS. The 8-channel version is $279.
-----Original Message-----
From: Gomella, Andrew (NIH/NHLBI) [F] [mailto:[email protected]]
Sent: Thursday, July 11, 2013 5:22 PM
To: Mark Rivers
Cc: [email protected]
Subject: RE: Simple wireless light controlled through EPICS?
The interlock came hardwired into our x-ray controller box. It's value can be read with the asyn stream driver and is a BO variable that reads whether the key is in the armed position or not. I was hoping to use this value to trigger lights on or off. Unfortunately I can't modify anything with the x-ray controller, so I figure there has to be some sort of USB light on the market that runs on serial commands? Or maybe such a specific thing does not exist and requires a micro-controller and some work to make.
Sent: Thursday, July 11, 2013 6:02 PM
To: Gomella, Andrew (NIH/NHLBI) [F]; [email protected]
How is your interlock done? Simple relays or with a PLC? Our laser interlocks here at APS use inexpensive PLCs, and they directly operate the warning lights outside the enclosure.
From: [email protected] [mailto:[email protected]] On Behalf Of Gomella, Andrew (NIH/NHLBI) [F]
Sent: Thursday, July 11, 2013 4:57 PM
To: [email protected]
Subject: Simple wireless light controlled through EPICS?
Anyone have any suggestions for a simple way to control a light with EPICS? It does not need to be bright, even a small LED will do. Basically I'm trying to have indicators on several doorways to show the current status of the interlock on our x-ray source (which is already a PV).
In the ideal scenario it would be connected to wifi so that ethernet/usb cables do not need to be run everywhere. I was thinking of maybe trying to get the "Belkin WeMo Home Automation Switch" to work with EPICS, it is basically a power plug that connects to WiFi. But it is probably easier to find some USB LEDs and run cables.
I know some beamlines at APS have EPICS controlled lights, so wondering if anyone has ideas?
Thanks!
Andrew
- Simple wireless light controlled through EPICS? Gomella, Andrew (NIH/NHLBI) [F]
- RE: Simple wireless light controlled through EPICS? Mark Rivers
- RE: Simple wireless light controlled through EPICS? Gomella, Andrew (NIH/NHLBI) [F]
Re: Simple wireless light controlled through EPICS? Maren Purves
<2013>
<2013>
